essexfocus Posted September 9, 2010 Share Posted September 9, 2010 Hey all, I need some help with a little problem and i'm hoping someone on here can help!? I've got a 2.0Tdci Focus Titanium and when pulling away and going through the gears, i get a stutter in power, it seems to happen as i reach about 2000 rpm and continues each time i move up through the gears, when the rev's drop the problem goes, at first i thought it may be a blockage in the fuel filter but thats been replaced in a service i have just had and the problem is still there. Any suggestions as to what may be the problem will be greatly accepted!! Many thanks in advance!! Paul Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 9, 2010 Share Posted September 9, 2010 sounds like a split intercooler pipe which is the pipe from the bottom of the egr valve, have you got an increase in black smoke? Quote Link to comment Share on other sites More sharing options...
Leemaxd Posted September 9, 2010 Share Posted September 9, 2010 Or the dreaded egr valve needs cleaning or a good one fitting like I am gonna get done on mine soon. Quote Link to comment Share on other sites More sharing options...
zev Posted September 24, 2010 Share Posted September 24, 2010 Or the dreaded egr valve needs cleaning or a good one fitting like I am gonna get done on mine soon. I have a simular problem only it just in 1st gear it seems to pull back/lose power for a few seconds then its fine going through the rest of the gears.Could it be the same problem as pauls. zev Quote Link to comment Share on other sites More sharing options...
Leemaxd Posted September 25, 2010 Share Posted September 25, 2010 I have a simular problem only it just in 1st gear it seems to pull back/lose power for a few seconds then its fine going through the rest of the gears.Could it be the same problem as pauls. zev The first thing I would try is the wynns egr spray treatment, cleans out your system and it's easy to do and really cheap at about £7 a tin, I had a stuttering problem used this stuff and it sorted it. Quote Link to comment Share on other sites More sharing options...
essexfocus Posted May 22, 2011 Author Share Posted May 22, 2011 Does anyone know where i would find the EGR valve on my 2.0 tdci engine? is it easy to get to? Many thanks Quote Link to comment Share on other sites More sharing options...
Sara Fiesta Posted May 26, 2011 Share Posted May 26, 2011 Yes mine stutters between 1200 and 1800 revs especially if my trying to crawl along in traffic. Quote Link to comment Share on other sites More sharing options...
