Scan Tool
can anyone recommend a good scan tool for the ranger wildtrack 2.0 eco 2021, thanks in advance
The very best that you can get is FORScan, it is as close as you can get to the Ford dealers own.
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
FORScan can read automatically with the vLinker devices both the HS and MS canbus systems. It will also read the Ford specific DTC's (unlike generic readers).
I tetested myself
Is it easy to use ?
Been watching post lol
3 minutes ago, Kitchenfitter said:
Is it easy to use ?
Start with using one of the phone versions. You can't cause any harm to you car with the phone versions since they do not allow programming, only reading of DTC's and the resetting of codes and service indicators.
The Laptop version will allow you do make changes to your vehicle. Just always remember to back uo the file before the change and then if you get it wrong you can Just go back.
Thank you appriciate info
