Bigger rims?
i have a focus 2020 mk4 titanium, it has 16" rims stock but i want bigger and wider rims is that possible or is there a way to get this info easy? i have no idea what im doing
We got you the 1st time... LOL
https://www.fordownersclub.com/forums/topic/154952-bigger-rims/
8 hours ago, -Palp- said:
You posted same question twice, post linked above now deleted...
ST-Line has 18" wheels.  ST has 19" wheels.  So they do physically fit a Mk4.  But they look ridiculous on a Titanium unless you lower the ride height at the same time.  Ride comfort will also be considerably compromised as the tyre sidewall has to be reduced by an inch for every extra inch of rim.
On earlier models, they also had to fit steering rack limiters with larger alloys, to stop the wheel hitting the inner arch on full lock.  Sure I've read the Mk4 doesn't need them for some reason (possibly an electronic limiter instead) but you would need to confirm that before fitting ideally.
In addition to Tom's points above, a further issue with bigger rims/lower profile tyres is they are far more vulnerable to damage from kerbing, potholes, etc.
I put 17's on mine wish i hadn't
I have a Focus 2019 Mk4 Titanium X, which has factory fitted 17" rims. They seem well suited to the car, handling is good, ride comfort good, and they look right.
