Intermittent clutch pedal 2012 3.2
Trucks recently developed an intermittent clutch pedal,driving around slowly seems OK not always anything over 2000rpm pedal sticks down, left for a period of time sometimes it disappears sometimes it's fine. No visable leaks and fluid reservoir is full and remains full any ideas?
Very likely the clutch slave cylinder seals.
Only way to check is to replace it.
Yeah it's just had a new LOF uprated clutch and slave cylinder fitted and seems fine bar the fact now gearbox light is flashing and power train light is on drives fine. Scan tool cam back with diff lock switch open load which will not clear any ideas???
