ABS initialization/relearn mistake.
Hey everyone, not new to diagnostic but new to forscan. Has anyone started the procedure for ABS initialization/relearn and completed it. now I have engine warning light. abs light emergency brake light and traction control light all on with no configuration with abs module.... I have read and seen videos to do this but there is no ABS as built format. if someone can shed some light on this topic for me that would be awesome....
Welcome!
Do you mean that there is no communication with the ABS module, in which case that needs sorting by checking fuses/CAN wiring/powers and Earths (don't forget to load test)
If the module is reachable by Forscan and genuinely needs to be re-initialised, I'm unsure Forscan can do it although specialist ABS repairers such as our UK companies like:
https://www.ecutesting.com/common-faults/ford/ford-ranger-abs-failure/
If it's a deep technical issue that I'm butting in about, sorry!
5 hours ago, Shearers said:
Welcome!
I wasn't tracking down a fault. I didn't have any issues with the ABS and I do not know why but I did do a ABS module initialization/relearn from central configuration and have had issues from there.... I am based on the other side of the world sorry, In New Zealand
Whilst I'm sorry, I don't understand what has been done, I hope that someone else can advise you as I can't.
