3.2 ROADTRAIN LIGHT SPORADIC
Hi there
My roadtrain light flickers on when you put the throttle down heavy and then looses power.
have changed fuel pump , filters, high pressure fuel sensor.
nothing appears when plugged in for diagnostics.
Any ideas?
Are you sure you're posting in the right forum Antony ?
This is for the Ford Ranger, the Roadtrain forum is bigger and a lot longer 🤣
See handbook warning about not using heavy acceleration when there is a power train fault (page55).
https://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/ENUSA_CG3575_RAN_og_201312.pdf
You need to use FORScan and get the Ford specific DTC's in order to find the issue.
