Forscan help needed
Hi
I recently got a Ford Ranger, 2019 2wd XLT. The previous owner disabled the front and rear parking sensor, but I want to get them to work.
What / where must I go in Forscan to get them working again. I just downloaded Forscan, and got the 2 months premium access.
There is a lot of areas in Forscan, so I want to make sure I don't mess anything up
Any help on where to find the correct module will be much appreciated.
Thank you
Firstly have you got the right lead? (V-Linker or OBDLink-EX?)
Go into configuration & programming
Scroll down and find the PAM and see if it's deactivated, if it is reactivate it.
If it isn't
Then it'll be in either central configuration (not asbuilt) or BCM (again not asbilt)
Find the park aid boxes and enable them and click write all at the bottom of the screen
