Zoggy Posted December 22, 2010 Share Posted December 22, 2010 Hi, i have recently bought a Ford Escort 1.8 SI [98], it's in pretty good condition considering its age, there's only a few annoyances i need to take care of, but the most immediate thing i need to sort are my dials,my oil gauge isn't working,and when driving at [x]mph, the speed dial needle hovers and wobbles quite a lot around the actual speed im doing,surly this should be steady?,everything else works fine though! Does anyone know how to fix this annoyance please? Thanks for any help in advance! Quote Link to comment Share on other sites More sharing options...
1987 xr3i cab Posted December 23, 2010 Share Posted December 23, 2010 i mate check your speeddo cable is plug in propley Quote Link to comment Share on other sites More sharing options...
RShaun Posted January 5, 2011 Share Posted January 5, 2011 Spedo bounce is a common fault on fords, if you`re lucky then its a loose cable but it normaly turns out to be the drive wheel in the g/box, not too big a job to sort just a pain in the !Removed!!! Check all the plugs on the dials as its probably loose conections Quote Link to comment Share on other sites More sharing options...
