wooburger Posted January 16, 2011 Share Posted January 16, 2011 Hi, I have a slight problem. I recently changed the fuses on my audio unit and when I started the unit up it asked for a key code. I tried the obvious 1111 and 1234 but to no avail. Any suggestions Quote Link to comment Share on other sites More sharing options...
taffg Posted January 16, 2011 Share Posted January 16, 2011 Hi, I have a slight problem. I recently changed the fuses on my audio unit and when I started the unit up it asked for a key code. I tried the obvious 1111 and 1234 but to no avail. Any suggestions you will need the serial number of the unit. try pressing 6 and 1 or 6 and 2 this may give you a list of figures which may include your serial number. post these figures and someone may be able to give you the code. if this doesnt have the serial number you will need to pop your radio out and the serial number will be on the radio ident plate. it should start with the letter m followed by six digits. post the ser no and someone will provide the code. Quote Link to comment Share on other sites More sharing options...
wooburger Posted January 17, 2011 Author Share Posted January 17, 2011 you will need the serial number of the unit. try pressing 6 and 1 or 6 and 2 this may give you a list of figures which may include your serial number. post these figures and someone may be able to give you the code. if this doesnt have the serial number you will need to pop your radio out and the serial number will be on the radio ident plate. it should start with the letter m followed by six digits. post the ser no and someone will provide the code. Hi, I got the serial number which is S0CD1X7V023110 Quote Link to comment Share on other sites More sharing options...
taffg Posted January 17, 2011 Share Posted January 17, 2011 see other post u made wooburger. Quote Link to comment Share on other sites More sharing options...
