tone Posted April 3, 2011 Share Posted April 3, 2011 Hi Guys The Electronic Stability Programme is an option on most of the Fiesta's and I was wondering what would be needed to add it to a car without it. Do any of our knowledgable guys out there know if its just a software progamme thing or do we need to add some hardware bits as well. Quote Link to comment Share on other sites More sharing options...
MRC89 Posted April 3, 2011 Share Posted April 3, 2011 I was under the impression that all new Fiesta's came with ESP as standard, The Zetec S comes with a button to turn it off, (part of street pack). I could be wrong though... Quote Link to comment Share on other sites More sharing options...
zetec bevvie Posted April 4, 2011 Share Posted April 4, 2011 Any built from March 2010 will have the ESP fitted as standard. Before that date, it was an option. Quote Link to comment Share on other sites More sharing options...
AntonyJ Posted April 4, 2011 Share Posted April 4, 2011 Hi Guys The Electronic Stability Programme is an option on most of the Fiesta's and I was wondering what would be needed to add it to a car without it. Do any of our knowledgable guys out there know if its just a software progamme thing or do we need to add some hardware bits as well. In addition to the traction control/ABS bits (throttle control and brake on/off per wheel) the ESP requires a yaw sensor (under the driver's seat IIRC) to detect sideways motion. In older cars there was also a steering wheel position sensor, but as the Mk7 has electric steering, I assume it just uses info from that. ESP just compares the actual sideways motion from the yaw sensor against the wheel speed and steering wheel angle and tries to compensate for any under/over steer by applying the brakes and adjusting the throttle. So it is mostly software, but you'd need the yaw sensor, a new wiring loom and the hard bit of getting the software updated (I doubt you'll find a dealer who would do this, but you never know). Quote Link to comment Share on other sites More sharing options...
