Fiesta Td Electrical Problem
Tomo2482
Hi,
I have a Fiesta TD 2001 and my battery continually drains overnight unless I disconnect the negative lead. I have had a new alternator, recon starter (tested today its fine), and I am on my second battery. If I leave it connected when I turn the key all the lights come on and the speedo needle goes round but no noise or cranking engine. My garage and a auto electrician can find no drain or fault. Can anyone help all help appreciated.
Hi,
hi mate this link might help
you did me
you did me
Just tried my small 12v tester and only thing drawing a small amount of power is the clock its on all the time so I have disconnected it will see if it starts in the morning !!!!!
Just disconnected 3 amp violet ecu fuse in engine bay and drain has gone down from 3 amp to 1.3 amp car starts and drives fine ? confused ????
