Escort Mk 6 1.6
smoothdriver108
Hi The Drivers Air bag warning light continually flashes, is there a known fault/ fix for this problem ? tia
Under the drivers seat there will be a yellow wire with a plug leading to another yellow wire going to your seat belt pre-tensioners.
Disconnect the plug, give it a good clean and put it back together. This is a very common problem and sometimes happens by people putting stuff under the seat or even just moving the seat and disturbing the connection.
Thanks Vinny, but no luck there, the connection seems clean and sound (unless a tiny wire inside is broken.)
count the flashes it will give a code, e.g ---- two second break -- =42
AIRBAG FAULT CODES
— No Air Bag Indicator — Inoperative Indicator Circuit
— Continuous Air Bag Indicator — Diagnostic Trouble Code Timed Out, Diagnostic Monitor
Disconnected or Inoperative, or No Ignition Voltage to Diagnostic Monitor
12 Lost battery Feed
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Diagnostic Monitor Not Mounted to Vehicle Properly
22 Safing Sensor Output Circuit Shorted to battery Voltage
23 Memory Clear Circuit Improperly Grounded
24 System Disarm Failure or Internal Diagnostic Monitor Fault
32 Driver Side Air Bag Circuit High Resistance or Open
33 Passenger Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Circuit Low Resistance or Shorted
41 Right Radiator Primary Crash Sensor Feed/Return Circuit Open
42 Left Radiator Primary Crash Sensor Feed/Return Circuit Open
44 Right Radiator Crash Sensor Not Mounted to Vehicle Properly
45 Left Radiator Crash Sensor Not Mounted to Vehicle Properly
51 Airbag diagnostic Monitor Internal thermal fuse Blown
52 Back-up Power supply Voltage Boost Fault
53 Front Crash Sensor High Resistance or Diagnostic Monitor Failure
  • Thanks 1
mintalkin - great thanks, it appears to be only 4 flashes then a 2 second break.
Weyhey fixed it - found this info : " 4 flashes of the light indicates the seat belt pre tentioners are at fault a common fault on this system
with the ign switched OFF look under both front seats you will see yellow electrical connectors disconect these conectors for 2 mins then re connect
turn on ignition your light should come on for about 10 seconds then go out and stay out.
  • Thanks 1
