Numpty7 Posted May 27, 2011 Share Posted May 27, 2011 Hi I need help unlocking my radio due to battery being disconnected, I have pressed 1&6 at the same time (I read this will bring the serial number up) and the info that came up was: FDC2005M144399, C307 02-03 17D_C, C820218 SA811000, NOV 7 2004, JA CB AT RW RL AR, don't know which bit I need or if this is any use to me at all?! Any help would be greatly appreciated Thanks Quote Link to comment Share on other sites More sharing options...
thenuttypuffer Posted May 29, 2011 Share Posted May 29, 2011 hi jennie, you need to pull your cd out the dash and you will see a model number, if you post it on here i will give you your code, ;) 1 Quote Link to comment Share on other sites More sharing options...
thenuttypuffer Posted May 29, 2011 Share Posted May 29, 2011 your m number was in that load of digits,lolol 8351 ;) Quote Link to comment Share on other sites More sharing options...
Numpty7 Posted May 30, 2011 Author Share Posted May 30, 2011 your m number was in that load of digits,lolol 8351 ;) Thank you all sorted now x Quote Link to comment Share on other sites More sharing options...
