Mike77 Posted May 30, 2011 Share Posted May 30, 2011 Hi guys, new to the forum, and to fords. Got a 1.4 TDCi mk6 fiesta, couple of problems I could do with some help with. 1,,, The central locking ( key in the door or keyfob ) will lock both doors on the car, but will only open the drivers door. So I have to get in and lean over to open the passenger door. I've tried the double press on the fob, but no different, also tried the re-programing of the fob ( ignition on and off 4 times till the beep etc ) still nothing,, any ideas anyone, I read somewhere on here about a procedure using the trip computer buttons, but it did'nt say what it involved. 2,,, While trying to tackle the above problem, ive somehow managed to mess up the working of the passenger window, it just wont come down, I can hear it trying to work while pressing the 'up' switch, but nothing for 'down'... all wires etc are visably fine, good connection of the loom from door to a-post, so im a little lost, and help would be great, thanks in advance, Mike. Quote Link to comment Share on other sites More sharing options...
Mike77 Posted May 31, 2011 Author Share Posted May 31, 2011 Hi guys, new to the forum, and to fords. Got a 1.4 TDCi mk6 fiesta, couple of problems I could do with some help with. 1,,, The central locking ( key in the door or keyfob ) will lock both doors on the car, but will only open the drivers door. So I have to get in and lean over to open the passenger door. I've tried the double press on the fob, but no different, also tried the re-programing of the fob ( ignition on and off 4 times till the beep etc ) still nothing,, any ideas anyone, I read somewhere on here about a procedure using the trip computer buttons, but it did'nt say what it involved. 2,,, While trying to tackle the above problem, ive somehow managed to mess up the working of the passenger window, it just wont come down, I can hear it trying to work while pressing the 'up' switch, but nothing for 'down'... all wires etc are visably fine, good connection of the loom from door to a-post, so im a little lost, and help would be great, thanks in advance, Mike. No1 got any ideas at all on this ??? Quote Link to comment Share on other sites More sharing options...
Chris 65 Posted June 5, 2011 Share Posted June 5, 2011 I recommend taking the car to a Ford garage. The techs there will probably be able to fix the problem quickly, and likely under warranty. Quote Link to comment Share on other sites More sharing options...
iNath Posted June 5, 2011 Share Posted June 5, 2011 I recommend taking the car to a Ford garage. The techs there will probably be able to fix the problem quickly, and likely under warranty. A MK6 Fiesta will be out of warranty. Quote Link to comment Share on other sites More sharing options...
aguycalledmal Posted June 5, 2011 Share Posted June 5, 2011 You will need to check the loom in the door sound like a broken wire Common fault due to the bending as the door is opened/closed It will be close to the plug Try undoing the plug then peel back the rubber and look for a broken wire. Quote Link to comment Share on other sites More sharing options...
