jingles Posted September 30, 2011 Share Posted September 30, 2011 just wondering if any one else gets this problem or if any body knows the solution. i have a 59 reg zetec s, and when im driving i get a noise from the passenger door area, that sounds like the window is not shut properly. havent really had a look as yet but was wonderiong if this could just be a manufacturing fault. thanks Quote Link to comment Share on other sites More sharing options...
dezwez Posted September 30, 2011 Share Posted September 30, 2011 just wondering if any one else gets this problem or if any body knows the solution. i have a 59 reg zetec s, and when im driving i get a noise from the passenger door area, that sounds like the window is not shut properly. havent really had a look as yet but was wonderiong if this could just be a manufacturing fault. thanks door may have been bent out at the top sometimes done when keys are locked in the car :o Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 30, 2011 Share Posted September 30, 2011 door may have been bent out at the top sometimes done when keys are locked in the car :o put the window down and youll see the seal around the inside of the window frame see if this is loose just push it in as its known for this to come loose with window use and need pushed back in you cant miss it it looks like that furry material rather than rubber Quote Link to comment Share on other sites More sharing options...
jingles Posted September 30, 2011 Author Share Posted September 30, 2011 put the window down and youll see the seal around the inside of the window frame see if this is loose just push it in as its known for this to come loose with window use and need pushed back in you cant miss it it looks like that furry material rather than rubber Thanks ill take a look when the wife gets back with the car Quote Link to comment Share on other sites More sharing options...
