cdk6468 Posted October 14, 2011 Share Posted October 14, 2011 We own a 2006 1.8 TDCI and it has 74.000 on the clock. On Wednesday it started making a blowing noise similar to when you turn the heater blower on but its coming from under the bonnet somewhere. It only happens when your driving and happens when you get to about 2ooo RPM, weve tried revving it whilst stationary but the noise doesn't happen. Any ideas anyone? Thanks Chris. Quote Link to comment Share on other sites More sharing options...
Big Budgie Posted December 3, 2011 Share Posted December 3, 2011 I don't know if you've got to the bottom of this yet, but it would seem that you have a leak on your turbo boost pipework. The turbo on the 1.8 TDCi seems to come to life quite suddenly at about 2000 rpm, whereas the 1.6 and 2.0 Which are Peugeot/Citroen engines, are more linear. It may just be a hose clip, or a split in one of the pipes, or it may be something more serious like damage to the intercooler. If you haven't already got it sorted, check over all the pipes between the turbo and the engine. If the leak is bad enough, it may even be causing the engine to lose power or smoke under load. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2012 Share Posted February 15, 2012 Hi everyone,I thought the engine were made at Bridgend centre of excellence by Ford and also fitted to Peugeot and Citroen,perhaps this could be confirmed,regards ccharlie. Quote Link to comment Share on other sites More sharing options...
