pumapuff Posted November 27, 2011 Share Posted November 27, 2011 I have just bought a 2000 V reg Puma, and the heater does not blow cold just seems to get hotter and hotter. Does anyone know why this is and how to cure the problem?. Also it seems to misfire sometimes, are these problems related? Quote Link to comment Share on other sites More sharing options...
btmaldon Posted November 27, 2011 Share Posted November 27, 2011 Hi It is most likely the heater control valve. Its a very common fault and fairly easy to replace. You can buy one from Fords for under £40 and there are just four water pipes and one electrical connection to disconnect and reconnect. If you look under the bonnet in the centre and on top of the bulkhead you can see it. Quote Link to comment Share on other sites More sharing options...
pumapuff Posted November 27, 2011 Author Share Posted November 27, 2011 Hi It is most likely the heater control valve. Its a very common fault and fairly easy to replace. You can buy one from Fords for under £40 and there are just four water pipes and one electrical connection to disconnect and reconnect. If you look under the bonnet in the centre and on top of the bulkhead you can see it. Cheers, will have a look :) Quote Link to comment Share on other sites More sharing options...
