simba Posted December 15, 2011 Share Posted December 15, 2011 Hi guys, Today when turning the car on the ESP light stays on. The car is handling and braking normal. Checked the DTC code and there is one: DTC #01 A895 Does anyone know what this means? Thanks Quote Link to comment Share on other sites More sharing options...
simba Posted December 15, 2011 Author Share Posted December 15, 2011 Forgot to say I have a 2008 facelift 1.8 TDCI TITANIUM. Quote Link to comment Share on other sites More sharing options...
fernsie Posted December 15, 2011 Share Posted December 15, 2011 Error A895 could be "Trip Computer Mode Switch Circuit Failure" - See the linked page ... << click me >> The error also seems to show up a lot with error D900 accompanying it (D900 could be 'CAN Communication Bus Fault') - See links -- << click me >> --- << click me >> << Internal site link As is suggested on the last link, it may be worth resetting the codes and see if any return Quote Link to comment Share on other sites More sharing options...
simba Posted December 16, 2011 Author Share Posted December 16, 2011 Error A895 could be "Trip Computer Mode Switch Circuit Failure" - See the linked page ... << click me >> The error also seems to show up a lot with error D900 accompanying it (D900 could be 'CAN Communication Bus Fault') - See links -- << click me >> --- << click me >> << Internal site link As is suggested on the last link, it may be worth resetting the codes and see if any return What do those faults suggest? Anything serious? How do I reset the codes and would that make the ESP light turn off if it is reset successfully ? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 16, 2011 Share Posted December 16, 2011 Simba, you could buy a DTC / OBDII Code reader with a code reset facility. you would need to plug it into the OBDII port to the right hand side of the steering column (just where the coin scully is) and then press the reset code button. Either that or face the wrath of your dealers bill for the privelage! Quote Link to comment Share on other sites More sharing options...
simba Posted December 16, 2011 Author Share Posted December 16, 2011 Simba, you could buy a DTC / OBDII Code reader with a code reset facility. you would need to plug it into the OBDII port to the right hand side of the steering column (just where the coin scully is) and then press the reset code button. Either that or face the wrath of your dealers bill for the privelage! hi there, thanks for your help :) i think i might do that. can you recommend a reader for me? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 16, 2011 Share Posted December 16, 2011 hi there, thanks for your help :) i think i might do that. can you recommend a reader for me? Will reply to your other topic... Quote Link to comment Share on other sites More sharing options...
simba Posted December 16, 2011 Author Share Posted December 16, 2011 Will reply to your other topic... Thanks :) Quote Link to comment Share on other sites More sharing options...
