marg Posted January 17, 2009 Share Posted January 17, 2009 car fanI have a 2001 focus (not air conditioning) the fan will only work on the no 1 setting when i put it on any higher it starts groaning and stops , not good for this cold weather any ideas anybody please ????????????? Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 17, 2009 Share Posted January 17, 2009 car fanI have a 2001 focus (not air conditioning) the fan will only work on the no 1 setting when i put it on any higher it starts groaning and stops , not good for this cold weather any ideas anybody please ????????????? as far as im aware the blower motors are a weak point on the focus, sounds like your gonna need to get a replacement. Quote Link to comment Share on other sites More sharing options...
Russ Posted January 18, 2009 Share Posted January 18, 2009 car fanI have a 2001 focus (not air conditioning) the fan will only work on the no 1 setting when i put it on any higher it starts groaning and stops , not good for this cold weather any ideas anybody please ????????????? Check the 'ballast' ( if it has one ) which is normally attached to the fan motor ( or i hope it still is ) these are notorious for blowing, which if they do lets the fan only work on the first setting' although i see u mention it starts to "groan" on other settings which could be a dirty/bad connection or a knackered fan/switch. Had the same problem on a cavalier and it was the switch that was knackered. Quote Link to comment Share on other sites More sharing options...
marg Posted January 18, 2009 Author Share Posted January 18, 2009 as far as im aware the blower motors are a weak point on the focus, sounds like your gonna need to get a replacement. Quote Link to comment Share on other sites More sharing options...
marg Posted January 18, 2009 Author Share Posted January 18, 2009 is it a big job to replace then????????? Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 18, 2009 Share Posted January 18, 2009 is it a big job to replace then????????? I have never replaced one before but i assume the glovebox will need to be removed to get access to it. If you want i will send you the info on replacing it from the haynes manual tomorow? if you could pm me your email i will get send you the pages concerned. Quote Link to comment Share on other sites More sharing options...
marg Posted January 19, 2009 Author Share Posted January 19, 2009 I have never replaced one before but i assume the glovebox will need to be removed to get access to it. If you want i will send you the info on replacing it from the haynes manual tomorow? if you could pm me your email i will get send you the pages concerned. thats great thanks , my email is channygreene@hotmail.com and thanks for yr help :D Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted January 20, 2009 Share Posted January 20, 2009 My brother replaced his a couple of times. Fiddly but not impossible. Glovebox down and stand on your head in the footwell. In fact I believe that he put his in gear and took the handbrake off then laid across from the drivers side to get a better position. He might be along at some point to correct me.... Quote Link to comment Share on other sites More sharing options...
Whelk8891 Posted January 23, 2009 Share Posted January 23, 2009 My brother replaced his a couple of times. Fiddly but not impossible. Glovebox down and stand on your head in the footwell. In fact I believe that he put his in gear and took the handbrake off then laid across from the drivers side to get a better position. He might be along at some point to correct me.... That's a reasonable summing up, although I'd remove the glovebox completely as its only held on with 3 screws, and the job is fiddly enough as it is without that being in the way. There's a screw right at the back of the motor which is a complete cow to get at, hence the standing-on-head thing. You'll need a short crosshead screwdriver, although I found it easier with a ratchet driver. I had a few problems with my scrappie-sourced replacement, which is why I did it a few times. The first time it took me about 45 minutes, but I can do it in 10 now, easy. Quote Link to comment Share on other sites More sharing options...
brunomedina Posted January 25, 2009 Share Posted January 25, 2009 The fan engine is broken change this Here in UK this part is not be very expensive , buy a new one . Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted January 26, 2009 Share Posted January 26, 2009 The fan engine is broken change this Here in UK this part is not be very expensive , buy a new one . Bad advice, and you're not in the UK you're in Brazil. Here they are well over £100 for a new fan Quote Link to comment Share on other sites More sharing options...
brunomedina Posted January 26, 2009 Share Posted January 26, 2009 Bad advice, and you're not in the UK you're in Brazil. Here they are well over £100 for a new fan Jesus , i can't imaginate these prices here , it's very expensive , the same as here in brazil Quote Link to comment Share on other sites More sharing options...
Whelk8891 Posted January 26, 2009 Share Posted January 26, 2009 Jesus , i can't imaginate these prices here , it's very expensive , the same as here in brazil Er.... what? You're in UK yet you're in Brazil? You "can't imagin[at]e these prices here" yet they're "the same as here in Brazil"? I'm lost. Although, not quite as lost as you are, it seems. Quote Link to comment Share on other sites More sharing options...
