salsheikh Posted January 12, 2012 Share Posted January 12, 2012 guys, i have checked my service book and in there it does not ask if the cambelt has been changed. when does it need changing? my cars done 83k at present and is an 08 plate. anything else that needs doing at the same time? Quote Link to comment Share on other sites More sharing options...
Barry_ Posted January 12, 2012 Share Posted January 12, 2012 Ford say at 100k but its recommended to do it earlier (about 80k) due to the tensioners. You would be best off getting it sorted now mate. Quote Link to comment Share on other sites More sharing options...
young fez Posted January 12, 2012 Share Posted January 12, 2012 hi mate mines getting done at end of the month £196 fully fitted including parts,mines a 1.6 tdci,06 plate.part is £80 and labor is £116 so i guess its about a 2 hour job. Quote Link to comment Share on other sites More sharing options...
salsheikh Posted January 13, 2012 Author Share Posted January 13, 2012 is that at a Ford garage? what parts are they changing exactly? On VW/Seats/VAG cars it was advised to change the waterpump and cambelt at the same time, anything I should be aware of to change at the same time? Quote Link to comment Share on other sites More sharing options...
mcyoungy Posted January 14, 2012 Share Posted January 14, 2012 are you sure it's 100k? I was under the impression that the later diesels were 125k. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 15, 2012 Share Posted January 15, 2012 all fords 100k however thats the belts only not the tensioners the tensioners have been known to fail early therefore hire companies etc recommend 60k as normal ford will charge around 200 quid for the full kit timing belt fan belts tensioners labour and new bolts and its gauranteed it also maintains the 100k on the belt Quote Link to comment Share on other sites More sharing options...
mcyoungy Posted January 15, 2012 Share Posted January 15, 2012 I don't think so. The Ford service schedule for my 06 1.8tdci says 125k. You can check your own vehicle on the etis site: http://www.etis.ford.com/fordservice/serviceScheduleForm.do Cambelts and tensioners can fail at any mileage................ PSA quote 100k for the 01-08 C5 but there was one I heard of failed at 37k. An exception I'd say, as you wouldn't suggest everyone got their belt changed at 35k because of that. Mine was changed at 100k with "no signs of distress". I had a Galaxy with the VW PD engine - cambelt due at 40k. The hire company that owned it never did get the belt done and I bought the car with 60k on the clock, not impressed I have to say but it shows that they can last well over the recommended interval. Quote Link to comment Share on other sites More sharing options...
young fez Posted January 15, 2012 Share Posted January 15, 2012 i have had a cam belt snap on my old ford diesel due to holding off doing it,belive me its not cheap to get repaired,so do it around 80k.for the sake of £200 better safe than sorry thats what i say. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 16, 2012 Share Posted January 16, 2012 its up to you its recommended 60k if you want to risk it for the sake of 200 quid thats cool but 16 valves at £11 a valve add labour etc ide rather pay the 200 than 600-700 if the tensioner goes. first sign of a worn tensioner is a tick from the belt are under idle that doesnt go away its pot luck as to wether it lasts or not as said they have went at 40k some 140k personally i do 60k even the ford mechs say that they wouldnt leave it that long 125k for a change ide never leave it that long even on a diesel trust me if it went at 100k and it was the tensioner all ford will do is slap you with a bill the belt only is gauranteed for that mileage not the tensioners so its down to piece of mind knowing its done Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 18, 2012 Share Posted January 18, 2012 I couldnt agree more with all the guys have said above, OK its bringing the bill forward by a few miles maybe a year even in some peoples circumstances, but if you dont know the cars history, and you dont thoroughly check these parts weekly or monthly so that you can see the deterioration, then you are taking a chance leaving it until 100k mark, 125 for a modern diesel is believable, and the belt may be able to manage it, but as the guys said, the tensioners and the pulleys are the weak link of the chain... if they go, then your looking to pay for the belt and tensioners, as well as artscot said - the valves and the labour at the very least, thats to say that it was a clean snap with very little damage, if it damages the crankshaft, then your well and truely stuffed... Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 18, 2012 Share Posted January 18, 2012 Sometimes it';s not milage that causes cambelt failure but driving styles. At work we have a 09 plate Vauxhall (spit) combo that we use for running training kit around, sometimes it can be driven by 20 different people during a week. It has done just over 39k and shed a cambelt just before christmas. Cue sound of crunching valves and mangled metal. AA was called and the first thing the guy did was try starting the vehicle!!! Twice!!! Suffice to say the vehicle was gone for 3 weeks and had a new engine fitted as the other one was well and truly scragged. Valves, pistons, rods, camshaft and cylinders were metal confetti. Unfortunately sometimes things just happen without warning. Just glad it wasn't my car. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 18, 2012 Share Posted January 18, 2012 but its a vauxhall wouldnt expect any less :D :D :D :D :D :D :D 1 Quote Link to comment Share on other sites More sharing options...
gumpy321 Posted February 3, 2013 Share Posted February 3, 2013 On the subject of timing belt kits, mine is due a kit (It's on 59k) and the Haynes manual recommends to change at 60k. I've just purchased a Gates' timing belt kit from Eurocarparts. Usually kits consist of the belt, and at least two tensioners. This only has the belt, bolts and one tensioner. No idler. I have looked on eBay at other kits and they are the same? Is this correct? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 3, 2013 Share Posted February 3, 2013 Thats what ford use so yes its correct it depends who you listen to some say do the water pump as well but its up to the individual Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 3, 2013 Share Posted February 3, 2013 is the water pump not driven from the auxiliary belt on these engines? therefor there is no need to change it when doing the timing belt. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 3, 2013 Share Posted February 3, 2013 On mine anyway its driven by the timing belt or so im lead to believe Quote Link to comment Share on other sites More sharing options...
gumpy321 Posted February 3, 2013 Share Posted February 3, 2013 I will ask my mechanic to look at the water pump and let him decide whether or not it needs replacing with the cambelt. Thanks guys. Quote Link to comment Share on other sites More sharing options...
Alan 50 Posted January 21, 2022 Share Posted January 21, 2022 Hi all my 2013focus estate diesel is getting ready , mileage 71.000 but what is the cost to replace belt and water pump .I am also wandering why you change the pump Quote Link to comment Share on other sites More sharing options...
Tizer Posted January 21, 2022 Share Posted January 21, 2022 2 hours ago, Alan 50 said: Hi all my 2013focus estate diesel is getting ready , mileage 71.000 but what is the cost to replace belt and water pump .I am also wandering why you change the pump A lot of Cambelt failures are caused because one of the ancillaries that are driven by it seize, so Water Pumps and Idlers are changed at the same time. if they are driven by the belt. Plus the belt often has to come off to change it if it is leaking and most manufacturers recommend that the belt is changed if it is disturbed, even if nearly new. Quote Link to comment Share on other sites More sharing options...
Phil3747 Posted January 21, 2022 Share Posted January 21, 2022 Not so long ago the replacement belt and water pump were supplied as separate items but now the likes of Dayco supply them together as a kit. Quote Link to comment Share on other sites More sharing options...
Barry150 Posted January 23, 2022 Share Posted January 23, 2022 My Mk3 1.6 diesel is getting near to belt and water pump replacement Ford quoted me Nearly £800 is that right?? Quote Link to comment Share on other sites More sharing options...
isetta Posted January 23, 2022 Share Posted January 23, 2022 I don’t know current prices but it sounds a lot. Changing the belt on that engine is relatively easy compared to some other more complicated engines. I wonder if it’s high due to them factoring in the highest price for the genuine Ford parts. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted January 23, 2022 Share Posted January 23, 2022 Sounds like that quote was from a Ford dealership so it'll be their labour charge that's causing that huge price. Genuine cambelt & waterpump kit for the 1.6 TDCI is about £175 iirc. Quote Link to comment Share on other sites More sharing options...
jayvee Posted January 25, 2022 Share Posted January 25, 2022 On 1/18/2012 at 4:06 PM, jeebowhite said: I couldnt agree more with all the guys have said above, OK its bringing the bill forward by a few miles maybe a year even in some peoples circumstances, but if you dont know the cars history, and you dont thoroughly check these parts weekly or monthly so that you can see the deterioration, then you are taking a chance leaving it until 100k mark, 125 for a modern diesel is believable, and the belt may be able to manage it, but as the guys said, the tensioners and the pulleys are the weak link of the chain... if they go, then your looking to pay for the belt and tensioners, as well as artscot said - the valves and the labour at the very least, thats to say that it was a clean snap with very little damage, if it damages the crankshaft, then your well and truely stuffed... Yes all agree,60k change cam belt,water pump, idler,tensioner, acc belt,idler,tensioner. Quote Link to comment Share on other sites More sharing options...
