Neilc Posted January 15, 2012 Share Posted January 15, 2012 Hi I have been looking around the site for the answer but cannot find it so here goes, I have just bought a 2001 Mondeo TD LX with all four electric windows before I completed the purchase I checked each window from the main switch bank in the drivers door, they all worked. Today I have discovered that the passengers side and the rear ones wont work off there individual switches, obviously as they work from the main switch banks its not the motors. If I lower the passengers side from the main bank and then try to use the passengers switch the window only goes up whatever way the switch is pressed. Any help appreciated Neil Quote Link to comment Share on other sites More sharing options...
fishpond 47 Posted January 15, 2012 Share Posted January 15, 2012 I know this might sound daft but I had a problem like this on another ford (probe) and it turned out to be the drivers (main switch in your case) faulty, changed the switch and the problem was sorted, maybe the switch has been changed from a differant year or something, might be worth calling into an auto electricians before starting to fork out money on buying new switches you may not need. Quote Link to comment Share on other sites More sharing options...
Brett420 Posted October 7, 2020 Share Posted October 7, 2020 😎 got a similar issue with my 2011 LX Mondeo wagon. Passenger front and rear work separately. Neither driver front and rear nor both passenger windows work from main control. 4 buttons Quote Link to comment Share on other sites More sharing options...
