robmanmanc Posted January 16, 2012 Share Posted January 16, 2012 Sorry if this is about the millionth time someone has asked about a fuse... however, I've just bought a second hand Fiesta Mark 6 '03 TDCI and I don't really want to take it back to the dealer to have to wait a week to get it back just because the 12v socket isn't working. I've had a look under the gear stick and the socket is connected, I've just had a looked at the central fuse box and the fuse with the smoking cigarette symbol (presume this is the right one) 5th from left 3rd one up from bottom looks fine. However it's a 3amp fuse, everywhere I look it says it should be a 15/30AMP. Could this be causing the problem? Any ideas suggestions would be great. I'm fairly handy, but only just finding my feet with Car DIY. So nice and simple language please. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 16, 2012 Share Posted January 16, 2012 3amp fuse is way too small mate, a 3amp fuse would be used to power your interior dash lights or somthing similar, its way too low for your 12v socket id change it for a bigger one check the owners manual for a guideline on the correct amp of fuse to use. Quote Link to comment Share on other sites More sharing options...
ONETrueSaturday Posted January 16, 2012 Share Posted January 16, 2012 If in doubt get the multimeter out.... Quote Link to comment Share on other sites More sharing options...
kevin lancelott Posted January 17, 2012 Share Posted January 17, 2012 It should be a 30 if I remember.Had to put a new one in mine the other month. Quote Link to comment Share on other sites More sharing options...
robmanmanc Posted January 17, 2012 Author Share Posted January 17, 2012 Thanks for the replies. I thought 3 looked too small sadly the owners manual only tells me what different colours mean in terms of amps not where they go. I'll try and pick up a multipack of fuses or get a 30. If 3 is to small then it must have instantly blown, although it does look intact I guess it could be a hairline split. Quote Link to comment Share on other sites More sharing options...
Xulu Posted January 21, 2012 Share Posted January 21, 2012 Buy yourself a Haynes manual for Ford fiesta. Tells you all you need. Brilliant troubleshooter, and assistance for small jobs you can do yourself. Had it not been half 1 I would go get mine to tell you but I will get back to you on what it says. Check inside the cig lighter that there is nothing inside it causing an arc or shorting it every time you try a new fuse. Quote Link to comment Share on other sites More sharing options...
