talksy Posted July 4, 2014 Share Posted July 4, 2014 Thanks for your post, I think your first option may be the best. You make it sound so easy. How would I go about fitting a relay and run the sensor feed from ignition live to the relay you suggest? Are there any guides on this? The last time I touched wiring, I buggered the speaker wiring loom for my T reg Focus, I vowed never to go near any car wiring again! its constant feed,However you could fit a relay then run the sensor feed from an ignition live to the relay,This would result in power only flowing when the ignition feed is live,Another option is:Change the 12v socket fuse location,You see ford have two power supplys for the 12v sockets in the car,If you have the fuse in socket 1:The 12v sockets are constant live up to exactly 1 hour after engine off.The GEM shuts down to save power after 1 hour.Socket 2:The 12v sockets only become live when the key is turned in the ignition.But i dont know for sure if the 12v supply in the boot is fed from the same supply so you would need to try changing fuse socket an try it,It may not be on the same supply because its origional purpose was to power a 12V foam tyre compressor which is why i suspect it is always going to be a constant live. Quote Link to comment Share on other sites More sharing options...
pjcallow Posted August 31, 2014 Share Posted August 31, 2014 NICE ONE!!! 1 Quote Link to comment Share on other sites More sharing options...
TDCiST Posted August 30, 2016 Share Posted August 30, 2016 I've finally got round to doing mine!! Works a treat! Great guide Lenny! dont suppose you know what the black connector is for do you? That was taped next to my orange one... 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 31, 2016 Author Share Posted August 31, 2016 5 hours ago, TDCiST said: I've finally got round to doing mine!! Works a treat! Great guide Lenny! dont suppose you know what the black connector is for do you? That was taped next to my orange one... Could be for reversing sensor module I don't know, didn't have that one myself Quote Link to comment Share on other sites More sharing options...
TDCiST Posted September 10, 2016 Share Posted September 10, 2016 No it can't be that, I have sensors and they are plugged in elsewhere... Never mind, probably find it was a earth and I wouldn't have needed to run my own!! Quote Link to comment Share on other sites More sharing options...
Vinnybhamra Posted September 15, 2016 Share Posted September 15, 2016 On 1/18/2012 at 4:17 PM, Lenny said: Thanks for the comments guys, the positive feed would also be useful for anyone who planned to fit a sub in the boot, this cable would save them over an hour fishing a live feed from the battery all they way through the firewall and interior to the boot. the focus is full of secrets :D footwell lights, ST Pod markings under the dash, secret diagnostic menu, and now this additional 12v socket in the boot, the car just keeps on giving I had literally just been thinking the same thing, I've been looking to get my sub moved from my old car into my focus. Is this supply always live? because if so do you have any idea of a accessory supply that I can use so I don't have to fit a switch or anything? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 15, 2016 Share Posted September 15, 2016 The supply is permanent live the same as the front sockets. Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
spyroszar Posted June 4, 2020 Share Posted June 4, 2020 One more mod is completed. Once again, thank you Lenny for this very useful guide. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 4, 2020 Share Posted June 4, 2020 Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Fordfootforward Posted July 6, 2020 Share Posted July 6, 2020 Did anyone ever find out what the black connector next to the orange live feed did? Would be very interesting to know 1 Quote Link to comment Share on other sites More sharing options...
MCoop Posted July 7, 2020 Share Posted July 7, 2020 I did it today, will need to replace my rear winfow heater fuse now. provided my own ground wire to the bolt hole also tapped into the boot light to iluminate the ring 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 13, 2020 Author Share Posted July 13, 2020 On 7/7/2020 at 9:21 PM, MCoop said: I did it today, will need to replace my rear winfow heater fuse now. provided my own ground wire to the bolt hole also tapped into the boot light to iluminate the ring Nice touch adding the illumination 👍 You may also like: Guide to Fitting additional Boot Light Click Here 1 Quote Link to comment Share on other sites More sharing options...
gloves Posted October 4, 2020 Share Posted October 4, 2020 this may sound silly but how do the ford sockets stay in place? all the third party ones I've bought have a thing you screw on the back, do clips hold the front and socket together with the ford ones? 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 4, 2020 Share Posted October 4, 2020 The surround needs to go in first then the socket locks in and splays out lugs.Sent from my SM-G965F using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
MCoop Posted October 8, 2020 Share Posted October 8, 2020 On 7/13/2020 at 4:40 PM, Lenny said: Nice touch adding the illumination 👍 You may also like: Guide to Fitting additional Boot Light Click Here i have thought of it 1 Quote Link to comment Share on other sites More sharing options...
gloves Posted October 25, 2020 Share Posted October 25, 2020 Thanks for the guide! I just did this mod, all is well but one thing. One of the plastic fasteners is stuck in its metal counter part. the problem is the plastics its meant to be fastening down are not with it. I've tried digging it out with pliers with no luck. any tips? I assume i might need a needle nosed tool for it. Quote Link to comment Share on other sites More sharing options...
