Focus Mk1 Boot Wiring Loom
Darren Cook
Hey, noticed whilst repairing a leak in the boot that someone's messed with the loom extended wires and one is lose with seemingly no place to connect..
its a orange and green wire. any ideas?
Pictures below.... Click for bigger image
Searched around and this might be yellow/green and be rear fog light?... any input on if im right. my multimeter doesn't fit into this connector to test for +12v on fogs on.
I think the only way to check for sure is to cut into it and test the voltage , being in the boot it may also have been a power feed if some one had used a sub in there
Only thing sub wise it could be is a signal line (ignition on/off) as its far too thin for power. (would be 10 gauge (400watt) or thicker)
I will just cut the connector off. doesn't connect to anything that i can see anyway.. cheers.
