MrRedman Posted February 21, 2012 Share Posted February 21, 2012 Hi everyone, I cant get anything out of my rear wash wipe and the front are not great i think there maybe dirt onside the bottle as ive syphoned it out a couple of times and see some. Is there anything i can put in the bottle to dissolve this or should i be removing it and cleaning it out away from the car? If so how do i best remove it? Cheers.. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 21, 2012 Share Posted February 21, 2012 Start by flooding the bottle and get the carbon out, otherwise you will be removing the bottle and the wheel arch lining, then the lines, and maybe even the pump, which will not be fun. Bare in mind, any chemicals you put in your bottle, will end up being sprayed onto your paintwork, and risk damaging it. I would say, flood the bottle, then drain it, re-secure, and put a couple of bottles of white vinegar into the bottle, then run it through the jets (even if you have a cloth or something to catch it before hitting paint). let it run through a little, then leave the washer bottle with some in overnight, as it will be in the pump / lines, it should dissolve any crap. Then I would say, flood out the remnants of the vinegar, fill up again, then run it through to push the vinegar out the last few inches of pipe/pump work :) Quote Link to comment Share on other sites More sharing options...
MrRedman Posted February 21, 2012 Author Share Posted February 21, 2012 Cheers ill pick some white vinigar up today and report back.. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 21, 2012 Share Posted February 21, 2012 Hi,have had this before,try putting hot not boiling water in bottle to dissolve frog spawn type gel that collects in bottom, Quote Link to comment Share on other sites More sharing options...
MrRedman Posted February 22, 2012 Author Share Posted February 22, 2012 Used a combination of both above posts worked a treat cheers Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 22, 2012 Share Posted February 22, 2012 i found the easiest way was shove the end of a hose pipe down into the bottle and just flush it all out Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 23, 2012 Share Posted February 23, 2012 Yeah I just like to clean the pump, the lines and the jets of any calcium as the hot water doesnt always do that! Mr Redman, Glad that the suggestions worked for you though! Quote Link to comment Share on other sites More sharing options...
