Daz-ST Posted January 24, 2013 Share Posted January 24, 2013 Is it not in the main menu under settings? I up graded my ROM file and cannot remember if it has disappeared or not but can check later. Failing that via the ELM software in the HEC Module I believe you can change it there in Page 2 of the Configuration No it has disappeared. Yeah know you can use the software to change it but would like it back in the car If you could check that would be great pal. The only other that been done to the car is that i have had a RS clutch fitted so the gearbox has been out . So wondering if something been missed on refitting it Quote Link to comment Share on other sites More sharing options...
jbeer Posted January 24, 2013 Share Posted January 24, 2013 No it has disappeared. Yeah know you can use the software to change it but would like it back in the car If you could check that would be great pal. The only other that been done to the car is that i have had a RS clutch fitted so the gearbox has been out . So wondering if something been missed on refitting it I have checked and yes I can get the settings on the car menu. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 26, 2013 Share Posted January 26, 2013 why cant i down load the soft ware ? keeps saying dont have permission .how do you install the soft ware ?can some one put how to up please Quote Link to comment Share on other sites More sharing options...
Preee Posted January 26, 2013 Author Share Posted January 26, 2013 Which software John Quote Link to comment Share on other sites More sharing options...
Preee Posted January 26, 2013 Author Share Posted January 26, 2013 anyone know what to turn on to get the steering setting on the clocks seem to have lost them when updated the clocks If you have lost the steering settings i have seen this before , try turning off HEC shift up. Did you not make any backups of your config before you changed any settings ? Quote Link to comment Share on other sites More sharing options...
nuno8210 Posted January 26, 2013 Share Posted January 26, 2013 I also read it before. Unchecking the Eco Shift light box should solve the missing steering settings in the menu. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 26, 2013 Share Posted January 26, 2013 Which software John for the elm,ive had to reset me laptop up. Quote Link to comment Share on other sites More sharing options...
Preee Posted January 26, 2013 Author Share Posted January 26, 2013 For ELMConfig the direct link is on the first page , it's a link not a stored file on the forum , so it does work as i tried it early on. Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 27, 2013 Share Posted January 27, 2013 For ELMConfig the direct link is on the first page , it's a link not a stored file on the forum , so it does work as i tried it early on. is that the lates software.there is one a few pages back that wont let me down load Quote Link to comment Share on other sites More sharing options...
Rayan2002 Posted January 27, 2013 Share Posted January 27, 2013 It does........in Russian No news about S-max English version yet Quote Link to comment Share on other sites More sharing options...
Preee Posted January 27, 2013 Author Share Posted January 27, 2013 is that the lates software.there is one a few pages back that wont let me down load Yes it is a direct link to civil-zz download page Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 27, 2013 Share Posted January 27, 2013 Yes it is a direct link to civil-zz download page cheers. Quote Link to comment Share on other sites More sharing options...
.Ryan Posted January 27, 2013 Share Posted January 27, 2013 I do need to get round to having this done, my current display is very slow and sluggish :/ Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted January 28, 2013 Share Posted January 28, 2013 Would this work on my ford focus econetic estate 59 plate? Quote Link to comment Share on other sites More sharing options...
Preee Posted January 28, 2013 Author Share Posted January 28, 2013 Would this work on my ford focus econetic estate 59 plate? Yes there will be various things that will work on your Focus Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted January 28, 2013 Share Posted January 28, 2013 Great will get on to it and let you know how it goes! Quote Link to comment Share on other sites More sharing options...
Preee Posted January 28, 2013 Author Share Posted January 28, 2013 Great will get on to it and let you know how it goes! Cool , remember to follow the golden rule ! , Save your configuration before you edit anything and keep the config files for each page safe , in case you ever need to go back to default. Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted January 28, 2013 Share Posted January 28, 2013 Cheers will do. I usually have backups of my backups :) Quote Link to comment Share on other sites More sharing options...
Daz-ST Posted January 29, 2013 Share Posted January 29, 2013 If you have lost the steering settings i have seen this before , try turning off HEC shift up. Did you not make any backups of your config before you changed any settings ? yeah all sorted now, read it on a focus forum in malaysia about unticking the shift up which i did and its came back. i have backups of all pages on the laptop, golden rule no 1. not sure if you can help me on another issue, i enabled dds on my 59 plate forcus st and the option on the dash to set tyres which works fine but i got a flat before but never got a warning. the things i enabled was HEC config page 1 epb level1/ dds level 2/3 ticked HEC config page 2 hec level 2/3 menu speedlock supression all ticked BCM config dds focus facelift kuga ticked is there anything i have missed Quote Link to comment Share on other sites More sharing options...
Preee Posted January 29, 2013 Author Share Posted January 29, 2013 I have seen this before where it does not work so there may be a setting in the abs module that neess changing . Which I dont think elmconfig can do Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted January 31, 2013 Share Posted January 31, 2013 Got my elm cable haven't modified it yet, but enabled radio display and the shift light, tried Eco mode but it didn't work guessing I need to do the update, tried the reverse sound and washer fluid level but the sound was annoying and I don't think I've got a sensor so disabled them both again. Quote Link to comment Share on other sites More sharing options...
zangaby Posted January 31, 2013 Share Posted January 31, 2013 Yes, for ECO mode you need to update. Quote Link to comment Share on other sites More sharing options...
Carl0s Posted January 31, 2013 Share Posted January 31, 2013 The shift up light is the red up-arrow on the dash? And is the "eco mode" supposed to do? Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 31, 2013 Share Posted January 31, 2013 The shift up light is the red up-arrow on the dash? And is the "eco mode" supposed to do? it tells you how well you have been driving Quote Link to comment Share on other sites More sharing options...
RobTdci Posted January 31, 2013 Share Posted January 31, 2013 Has anyone updated to the 509 ROM from a 203 Rom? I am just a little nervous that if I update mine from 203 to 509 that it may then not work with the other modules. Quote Link to comment Share on other sites More sharing options...
