Ford Focus Idle Air Control
kevws77
Hi, just following up with a question from a previous topic. I have just rung my local Ford Dealership to ask the cost of an Idle Air Control Valve, and was told that our car doesn't have one? It is an LX, Mark 2, 2006 Automatic. The throttle body is £330 plus VAT plus Labour (been having some starting issues). Does anyone know if this is correct that it won't have an IAC?? Could it be that the throttle plate is sticking then (if there is no valve)?
Thanks for your help.
If it's the throttle body that is sticking, surely you can normally strip and clean/de-coke these and refit ?
http://www.ebay.co.uk/itm/FORD-FOCUS-1-6-MK3-2005-07-THROTTLE-BODY-VP2S6U-9E927-F-/330708006476?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4cffbbb64c found these on eBay might be worth taking the chance specially if you pay through paypal covered if it dont work looks like an easy enough job to replace if you could get some one to do a forigner.
or is this the bit your after http://www.ebay.co.uk/itm/Idle-Speed-Air-Control-IAC-Ford-Escort-Fiesta-Focus-repl-XS6U9F715AA-1086369-/260964438253?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cc2b150ed i found a place in the states for brand new genuine ford bits that they ship to the uk yer had wait a bit longer and even with the import duty was less than half the price of stuff from here you would have to get hold of the part number though
if you can bear with me for a day or two i,ve got a load of mk1 focus spares in the shed the iac by what i can see from searching on eBay seems to fit various models so its possible i might have one you can have .
i have got one its off a 1.8 but no part numbers on it it sits below the inlet manifold at the rear two 8mm bolts hold it on it looks like a pretty standard piece that they fit on various models if it will help pm me and i,ll send it down
Thanks as always guys. This doesn't sound right. I thought maybe as is was an Automatic it was different, but not sure. I did a search and chat on eurocarparts.com but it came back with nothing. The person on the chat didn't know about it either. When I asked if it was something that was on other cars they said "not as a listed part". Is it a smaller part of the entire throttlebody then?
These look to have ones for a 2006 model.
http://www.ebay.co.uk/itm/Idle-Control-Valve-Ford-Please-Check-Fitment-/280853672575?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3AFocus&hash=item41642ef27f
Fords normally call these Air By-pass Valves. We call them Idle Control Valves. Maybe the guy didn't know what you meant when you called it Idle Air Control Valve.
I would have thought the automatic version should have the same one as a manual unless somebody else knows better.
http://www.ebay.co.u...=item4cffbbb64c found these on ebay might be worth taking the chance specially if you pay through paypal covered if it dont work looks like an easy enough job to replace if you could get some one to do a forigner.
This looks very similar to what I have looked at online. Thanks. I just have no idea where it is in relation to the throttle body ! I've had a under the bonnet at lunchtime with no obvious signs.
http://www.ebay.co.u...=item41642ef27f
That's what I think. Everywhere online there is thousands of references to the IAC. Only 1 mechanic I've spoken to actually understands what I have meant, and unfortunately, he lives miles away :(
