Ews Posted September 23, 2014 Share Posted September 23, 2014 Many thanks jbeer, I don't have access to a computer at the moment but will sort it out soon. Will that be the actual update I need then? For a 2011 Focus? Thanks again. Sent from Ews iPad. Quote Link to comment Share on other sites More sharing options...
jbeer Posted September 23, 2014 Share Posted September 23, 2014 Should be fine for the mk2.5's and yep includes all the necessary files Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 23, 2014 Share Posted September 23, 2014 The latest available update was released back in november 2012. The update could be downloaded from several official Ford websites. Some time ago Ford removed all links to the Audio Update from their websites. Some time ago I E-mailed Ford about this issue. I got the answer that Ford ended the support for the Bluetooth/Voicecontrol system which was available for the Focus MK2.5 (and some other Ford models). Because the support ended Ford also removed the Ford Audio Update from their websites. Novero (the manufacturer of the Bluetooth/Voicecontrol modules did also stop the production of the retrofit kits. Newer Phone models are officially not supported by the system and may cause problems (even with the latest available Ford Audio update). I buy/sell Bluetooth/Voicecontrol modules from time to time and noticed this problem a few times. On my own car I solved this by installing a new type Focus MK3 Bluetooth/Voicecontrol module. The Ford audio update is suitable for all Focus MK2.5 and early MK3 models with an USB connection. If the Ford audio update is not suitable or already installed you will get a message on the radio screen and the update proces will not start Quote Link to comment Share on other sites More sharing options...
Ews Posted September 23, 2014 Share Posted September 23, 2014 Ok great, sounds good. Many thanks again. Sent from Ews iPad. Quote Link to comment Share on other sites More sharing options...
huey45 Posted January 20, 2015 Share Posted January 20, 2015 Hi JW1982 Any idea if this will work on my 2012/62 Plate Focus Tit with Sony DAB factory fit radio ? Quote Link to comment Share on other sites More sharing options...
huey45 Posted January 20, 2015 Share Posted January 20, 2015 Hi All I think Ford did it to print money, when we all go in for updates its their licence !!! Quote Link to comment Share on other sites More sharing options...
JW1982 Posted January 20, 2015 Share Posted January 20, 2015 Hi JW1982 Any idea if this will work on my 2012/62 Plate Focus Tit with Sony DAB factory fit radio ? The Ford Audio Update is only suitable for the early versions of the Focus MK3 which have the same Bluetooth/Voicecontrol module as the Focus MK2.5. The part number of this module is 8M5T-19C112-XX. On this type of module the Voice control language can not be changed. Later versions of the Focus MK3 do have the same Bluetooth/Voicecontrol system but have a different type of Bluetooth/Voicecontrol module. The part number of this module is CS7T-14D212-XX. On this type of module the Voice control language can be changed by changing the vehicle language in the instrument cluster menu. At a later time the Bluetooth/Voicecontrol system is superseded by the SYNC system. The SYNC system is a complete different system. If your car has the first type of module you can perform the Ford Audio update. On the other modules the update will simply not work or an error will be shown on the display. Quote Link to comment Share on other sites More sharing options...
huey45 Posted January 20, 2015 Share Posted January 20, 2015 Hi JW1982 How do I know as owner without technical knowledge if mine can be updated, but from my FordEtis printout states my car was built 10/07/2012 and my VIN number to get that is WF0KXXGCBKCD71917, (ICE-Mid Audio Branded +DAB, Ice Feature Pack 8 ??) So I dont know if mine is Early or Late, but I think from memory there is a Language option change in Audio setup menu Comments please Quote Link to comment Share on other sites More sharing options...
JW1982 Posted January 21, 2015 Share Posted January 21, 2015 I checked the Ford Ecat parts catalog software and based on your VIN number your car should have the Bluetooth/Voicecontrol system with module part number CS7T-14D212-AG. The Ford Audio Update is not suitable for this type of module. Quote Link to comment Share on other sites More sharing options...
huey45 Posted January 21, 2015 Share Posted January 21, 2015 Hi thanks for that info, not being a techie i needed a second opinion.. Quote Link to comment Share on other sites More sharing options...
mike6688 Posted January 26, 2015 Share Posted January 26, 2015 Will installing the latest update also install past updates? Or does each update have to be done in order separately? Quote Link to comment Share on other sites More sharing options...
jbeer Posted January 26, 2015 Share Posted January 26, 2015 No installing an update overrides previous firmware and there is no rollback as far as I know of Quote Link to comment Share on other sites More sharing options...
efiste2 Posted September 12, 2015 Share Posted September 12, 2015 If i can get these files, for my 2011 focus how can I install them ? Quote Link to comment Share on other sites More sharing options...
jbeer Posted September 14, 2015 Share Posted September 14, 2015 This is only for the mk2.5 if you have a mk3 then it's a different software set up. Either way you would update via the USB port Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 14, 2015 Share Posted September 14, 2015 The Ford Audio Update is also suitable for the early Focus MK3. This update does only affect the Bluetooth/Voicecontrol module. The early MK3 did have exactly the same Bluetooth/Voicecontrol module as the Focus MK2.5 1 Quote Link to comment Share on other sites More sharing options...
