Akela Posted May 21, 2012 Share Posted May 21, 2012 Hi everyone, I am new to this forum and am hoping someone can help me. I have (I think) blown something up while fiddling with my Focus electrical system. I think I shorted out a thin green and white wire which goes to a connector inside the central console to the left of the gear lever. Everything still works, except that the auto lights are now permanently on manual, and the engine warning light is permanently on. I have checked all the fuses (I think) and they all seem OK. Does anyone know where this wire goes and what may have got damaged by shorting it? I am thinking maybe the GEM is involved somewhere, but I don't really know. I have a Haynes manual, but the wiring diagrams don't show that wire. If anyone has a proper wiring diagram, that would be a great help. The model is a 2008 Focus 1.6 TDCi Titanium estate. Attached is a picture which shows the connector, the green/white wire is just visible at the top. Thanks for any help - it's got me scratching my head! Mike. Quote Link to comment Share on other sites More sharing options...
Akela Posted May 22, 2012 Author Share Posted May 22, 2012 Hi Everyone, Update on this problem in case it helps anyone else. After re-checking all the fuses, I found that the one right at the back was blown. This is F100. Replacing that fixed all the odd electrical behaviour, but left on the engine warning light. That fixed itself after about 10 engine restarts. The only thing left now is that when I put the instrument cluster in test mode, I see "NVM EEPROM lvl 0001 FAIL". Everything else looks OK and there are no DTC codes showing. Anyone know what this error (if it is an error) means, and whether it is worth fixing. Thanks. Mike. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 22, 2012 Share Posted May 22, 2012 Glad you got it sorted. Sorry I dont know what the error message is. Eeprom normally relates to a form of memory. It maybe something to do with the fuse that went. Do you know anyvbody with a code reader. This will id the fault better and can clear it if it is still showing. Going back to your original issue, the only wires I am aware of that run through the console would be the handbrake warning switch, 12v socket power, if you have one there and auxilliary/USB connections if you have those under the arm rest. Quote Link to comment Share on other sites More sharing options...
Akela Posted May 22, 2012 Author Share Posted May 22, 2012 Thanks Mate. I think I will try to find someone with a code reader as you suggest. Ford charge £85 for this, so I think I need to find someone who will do it for a beer. :) The other cables in the connector in my pic are the 12V power outlet feed. The one I shorted doesn't actually go anywhere, but is obviously "live". I guess it feeds some option that I don't have. Thanks again. Mike. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 22, 2012 Share Posted May 22, 2012 I bought a code reader off eBay for £25. Best value tool I have ever bought. Saves a load of money. Quote Link to comment Share on other sites More sharing options...
Akela Posted May 22, 2012 Author Share Posted May 22, 2012 Thanks again for that suggestion. I thought these things would cost a fortune, but I just looked on amazon and you can get one for 17.99. Might be a bit of a toy for that price I suppose, but if it reads codes and turns off the light, then that's probably all I need. I think I'll give it a punt. Cheers, Mike. Quote Link to comment Share on other sites More sharing options...
coola1970 Posted March 25, 2014 Share Posted March 25, 2014 Hi This is not really a reply but more of a question. I have a 2008 tdi 6 speed manual Focus with a major electrical problem. occasionally when its wet the engine light, hand brake light stay on the air conditioner pump stops working but fan continues to operate correctly. also the dash indicators and side mirrors dont work but the front and rear do. The high beam dash light does not come on neither does cruise control or the central locking and as a last thing the outside temp display does not work also. Ive been told that its an earth fault but with a car that has upwards of 20 earth poinst and multiple wire joins does any one have any idea where to start looking. Thanks you Quote Link to comment Share on other sites More sharing options...
forcemdcd1 Posted December 11, 2019 Share Posted December 11, 2019 Alright Coola1970, I have a similar problem; hopefully if you did get a resolve could you share it? Forcemdcd1 Quote Link to comment Share on other sites More sharing options...
pcaouolte Posted December 11, 2019 Share Posted December 11, 2019 I hope that someone else will be able to help you. Coola1970 only posted once in 2014 and hasn't been back since. Quote Link to comment Share on other sites More sharing options...
isetta Posted December 11, 2019 Share Posted December 11, 2019 my understanding is that these items on the dashboard - indicator telltale lights, blue high beam light, indicator click sound and outside temperature display are all controlled by the MS Canbus (two wires - not separate wires for each thing). On my brother's 2008 focus, when these things stopped working it was a dodgy connector. I can't remember if it was one on the bottom of fuse box (fuse box is under the glovebox) or one next to front seat passenger's left foot under the carpet or plastic door post trim. (he had a few dodgy connectors) Quote Link to comment Share on other sites More sharing options...
forcemdcd1 Posted December 11, 2019 Share Posted December 11, 2019 Thanks for the heads up. It would help if looked at the date posted😳 I really appreciate the help. I'll look into that. Thank you.😁 Quote Link to comment Share on other sites More sharing options...
