macca73 Posted May 24, 2012 Share Posted May 24, 2012 Hi I have a 2002 Mondeo, 108 Zuratec. I made the dreaded mistake of running out of petrol. I filled out with a can of petrol (around £5) and the engine is just turning over and over. Doesn't sound like starting. I have tried again this morning and it turned over for a while, to no avail, but now won't turn over and makes a clicking sound (the dash lights also flicker). So am assuming I have drained the battery. Any ideas at all. Have I probably sucked up all the rubbish from the bottom of the tank? Any suggestion would be appreciated thanks Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted May 24, 2012 Share Posted May 24, 2012 are you getting a spark are the plugs wet??can u hear the pump start when you turn the ignition on before you start it??theres a depressurise valve on the fuel rail have you checked for fuel pressure of has fuel pump fuse blown hope this helps Quote Link to comment Share on other sites More sharing options...
