bigtoph Posted February 8, 2009 Share Posted February 8, 2009 hey all looking for some help here i am just wonderin if there is an upgrade front brake kit from ie maybe the st170 or rs and if they do do they take much work to get these to fit this is my first ford i am used to honda which were easy mods so any help is really helpfull so thanks in advance cheers Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted February 8, 2009 Share Posted February 8, 2009 hey all looking for some help here i am just wonderin if there is an upgrade front brake kit from ie maybe the st170 or rs and if they do do they take much work to get these to fit this is my first ford i am used to honda which were easy mods so any help is really helpfull so thanks in advance cheers ST brakes will fit but are VERY expensive. Last time I heard brake discs were around £140. Then I think the callipers are different too. You can get excellent aftermarket brakes for less than that. Quote Link to comment Share on other sites More sharing options...
bigtoph Posted February 8, 2009 Author Share Posted February 8, 2009 ST brakes will fit but are VERY expensive. Last time I heard brake discs were around £140. Then I think the callipers are different too. You can get excellent aftermarket brakes for less than that. cheers man the only reason i liked the idea of the st170 brakes is that they are 300mm discs as my focus has a set of 18s on it and the discs looked tiny behind them i was told that u needed to change the hubs also but i am totally new to this so i just wanted to see what my options are dont really wanna Shell out a grand plus for brembro or any of those brakes i found a company that can supply the calipers for 250 but i wanted to check everything out befor i start spendin money and cheers for the reply Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted February 8, 2009 Share Posted February 8, 2009 cheers man the only reason i liked the idea of the st170 brakes is that they are 300mm discs as my focus has a set of 18s on it and the discs looked tiny behind them i was told that u needed to change the hubs also but i am totally new to this so i just wanted to see what my options are dont really wanna shell out a grand plus for brembro or any of those brakes i found a company that can supply the calipers for 250 but i wanted to check everything out befor i start spendin money and cheers for the reply Now you mention that, I do think you need to change the hubs too. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2009 Share Posted March 7, 2009 And just to revive this - Are there any other brake updgrades that could be done using other Ford parts? Such as brakes from a V6 Mondeo etc? Quote Link to comment Share on other sites More sharing options...
