s.jsutton Posted June 29, 2012 Share Posted June 29, 2012 Hi all. Can anyone explain how to remove the outer bottom window weather strip on a rear door of a MK3? Have haynes manual which describes how to remove glass and tells you you have to prise off the strip, but this is after removing the door card and inner window rubber. Are you required to remove the inner strip to allow movement in the window so you can then prise off the outer, or can it be done from the outside without going down the road of removing the door card etc. The strips on my rear doors are bubbling up, I have some replacements from a scrappy [mondeo spares] that are in good nick and want to swap them this weekend, but the haynes way seems long. Any advise much appreciated. Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted June 29, 2012 Share Posted June 29, 2012 hi they are so easy to take off and u dont need to strip door dwn either just start from front edge of door and gently lift up with small screw drive then just pull up by hand,but obv gently pulling up on new1s as they will bend slightly but will go back ok 1 Quote Link to comment Share on other sites More sharing options...
s.jsutton Posted June 29, 2012 Author Share Posted June 29, 2012 Thanks Peter. Was hoping it was a simple one. Quote Link to comment Share on other sites More sharing options...
fintious maximus Posted June 29, 2012 Share Posted June 29, 2012 I just opened the windows on mine and gently pulled the strips skywards. Very easy to do! Quote Link to comment Share on other sites More sharing options...
s.jsutton Posted June 29, 2012 Author Share Posted June 29, 2012 Job done. About 1 minute per side, couldn't have been easier. Thanks guys. Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted July 5, 2012 Share Posted July 5, 2012 no prob mate had same prob with mine when i brought it lol Quote Link to comment Share on other sites More sharing options...
Ozzy ellis Posted May 1, 2020 Share Posted May 1, 2020 Hi I am proud owner now of a 1998 mondo saloon , I'm looking for full set of door to window glass weather strips . Ellisozzy@gmail.com any door would help but after all , kind regards Ozzy Quote Link to comment Share on other sites More sharing options...
Frembrit Posted May 1, 2020 Share Posted May 1, 2020 Whoa.. thread revival 😉 Welcome, They weren't cheap when I looked when I had my ST24 (W reg)...quick search on eBay gets this...https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=mondeo+mk2+door+weather+strip&_sacat=0&rt=nc&Brand%20Type=Genuine%20OEM&_dcat=14768 check fitment though. 1 Quote Link to comment Share on other sites More sharing options...
