Jit Posted August 18, 2012 Share Posted August 18, 2012 Can anyone help...my interior light doesn't switch off when the doors are closed and I lock the car, it always stays on unless I turn it off completely do you know what the problem is? Quote Link to comment Share on other sites More sharing options...
oilburner79 Posted August 18, 2012 Share Posted August 18, 2012 It sounds like one of your door pin switches is faulty Quote Link to comment Share on other sites More sharing options...
tunne1rat Posted August 18, 2012 Share Posted August 18, 2012 The current Fiesta does not have conventional pin switches. The courtesy lights work from the 'door ajar' switch located inside the door lock so unless your convers display is telling you there is a door open, it is not the door switch. It could be a faulty light unit or maybe the GEM needs rebooting. Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 19, 2012 Share Posted August 19, 2012 The current Fiesta does not have conventional pin switches. The courtesy lights work from the 'door ajar' switch located inside the door lock so unless your convers display is telling you there is a door open, it is not the door switch. It could be a faulty light unit or maybe the GEM needs rebooting. Still a possibility it's a faulty switch inside the lock mechanism Quote Link to comment Share on other sites More sharing options...
tunne1rat Posted August 19, 2012 Share Posted August 19, 2012 Still a possibility it's a faulty switch inside the lock mechanism The courtesy lighting is a much more complex affair on modern Fords, and is controlled entirely by the GEM. If a door switch were faulty, this would cause problems with the central locking too (ie the car would not double lock) and as I have previously mentioned, a door open warning would be displayed. The switch on the light unit is not too reliable and has caused many problems in the past, although you may find simply disconnecting the battery for a few mins will cure the fault. Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 19, 2012 Share Posted August 19, 2012 The courtesy lighting is a much more complex affair on modern Fords, and is controlled entirely by the GEM. If a door switch were faulty, this would cause problems with the central locking too (ie the car would not double lock) and as I have previously mentioned, a door open warning would be displayed. The switch on the light unit is not too reliable and has caused many problems in the past, although you may find simply disconnecting the battery for a few mins will cure the fault. oops, yeah i never thought of this. im having issues with a vw polo just now where the door is locked shut. from what i have inspected i reckon it could be a dodgy switch.. who on earth comes up with this junk.. Quote Link to comment Share on other sites More sharing options...
alexh89 Posted April 17, 2015 Share Posted April 17, 2015 Hi. I know this is an old thread but how did you resolve it? Cheers Quote Link to comment Share on other sites More sharing options...
