davecraggs Posted August 24, 2012 Share Posted August 24, 2012 my s max has developed a fault started in 3rd gear when reaching around 3000 rpm it will kangeroo cut out start ect and will not rev round past 4000 rpm its now happening in second revs fine in first and when not in gear im puzzeled its almost like some 1 pressing the brake on and off Quote Link to comment Share on other sites More sharing options...
137699 Posted August 24, 2012 Share Posted August 24, 2012 Check the wheel speed sensors / ABS sensors. If they're giving false readings the car will "cut" power to try to rectify what it thinks is a lock-up / slide. Quote Link to comment Share on other sites More sharing options...
davecraggs Posted August 24, 2012 Author Share Posted August 24, 2012 hi how would i check these not showing no faults up on car but i have just had a clutch fitted 1000 miles ago and it has slowly gotten worse since then Quote Link to comment Share on other sites More sharing options...
davecraggs Posted August 25, 2012 Author Share Posted August 25, 2012 changed fuel filter on a whim and it seems to off solved it Quote Link to comment Share on other sites More sharing options...
