led Posted August 27, 2012 Share Posted August 27, 2012 Recently change front pads and pushed back piston,like i`ve always done on previous cars,rather than crack open the nipple,apparently this can damage some seal or other on the abs is this the case or is it the norm thing to do any advise would be appreciated for future reference thx . Quote Link to comment Share on other sites More sharing options...
STEADS Posted August 27, 2012 Share Posted August 27, 2012 I,ve always pushed back the piston as long as the resivoir cap is off never had a problem and i,ve done hundreds and belive me this is the way they do it in a garage Quote Link to comment Share on other sites More sharing options...
led Posted August 27, 2012 Author Share Posted August 27, 2012 thx for that but people say it `flips some seal` i recently found out ,thanks for ur reply . Quote Link to comment Share on other sites More sharing options...
stef123 Posted August 27, 2012 Share Posted August 27, 2012 steads is right, even garages dont bother clamping hoses and opening bleed screws - certainly none that i know if you just open the resevoir you need to push the pistons back slowly and when you press the brake pedal to bring the pistons/pads back into place - make sure you only press it in small increments. Seals are easy to flip but in the same breath, done slowly and controlled its easy to do without damage. Quote Link to comment Share on other sites More sharing options...
led Posted August 27, 2012 Author Share Posted August 27, 2012 Thanks for your reply. Quote Link to comment Share on other sites More sharing options...
ferretfloozy Posted August 27, 2012 Share Posted August 27, 2012 i agree with stef & steds..it could flip the seal but i havent yet met anybody thats been unlucky enough to have it happen .. myself i prefer to clamp and bleed..only because i just know that i will be the 1 out of the 1000 that flips a seal ..knowing my luck i'll probably be the 1 out of 1000 that snaps the nipple if the seal did flip its more than likely because its worn and the pistons gone back unevenly.. Quote Link to comment Share on other sites More sharing options...
