stevebowser Posted February 20, 2009 Share Posted February 20, 2009 The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full. Quote Link to comment Share on other sites More sharing options...
zetec521 Posted February 20, 2009 Share Posted February 20, 2009 The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full. Clean the jet washer with a pin. It is probably blocked. Quote Link to comment Share on other sites More sharing options...
jeantech Posted February 20, 2009 Share Posted February 20, 2009 The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full. the only thing i can think of is the nossle is blocked try clearing it with a pin also put some screen wash liquid in it Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted February 21, 2009 Share Posted February 21, 2009 Get the car on some nice dry ground, give it a good squirt. Get out and see if your cars wet itself {big puddle under the side where the washer reservoir is}. If it has, probably the pipes blown off the pump. It happens a lot on fords especially if the wash freezes and you try using the washers. Quote Link to comment Share on other sites More sharing options...
Russ Posted March 1, 2009 Share Posted March 1, 2009 The front screenwash isn't working. One jet stopped then the other jet after a few days. I can hear the pump working. The rear screenwash works perfectly. The bottle is full. Would have thought the obvious thing to do would be to take the pipe off from the nozzel under the bonnet, squirt the washer and get someone to see if water comes out the pipe! If so the jets blocked, if not then either the filter in the bottle is blocked or the pipes come off at the bottle. Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted March 1, 2009 Share Posted March 1, 2009 Would have thought the obvious thing to do would be to take the pipe off from the nozzel under the bonnet, squirt the washer and get someone to see if water comes out the pipe! If so the jets blocked, if not then either the filter in the bottle is blocked or the pipes come off at the bottle. Would have to agree. If it isn't a blocked jet its most likely the bit gauze in the washer bottle behind the pump. Common problem in the fords unfortunatly. Quote Link to comment Share on other sites More sharing options...
