craig'sfordcmax Posted September 9, 2012 Share Posted September 9, 2012 hi i have an c-max 04 and driving home the battery light came on. the abs stopped working and the power steering whent stiff and hard to turn. thanks craig Quote Link to comment Share on other sites More sharing options...
gregers Posted September 9, 2012 Share Posted September 9, 2012 alternator? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 9, 2012 Share Posted September 9, 2012 Duff alternator or battery, though I'd be more inclined to alternator. Most likely worn brushes, give the alternator a whack to re-seat the brushes until you can get it checked. Over time the carbon brushes wear down and the springs cam on longer exert enough pressure to keep the brushes in constant contact. The reason the steering got heavy is because the car was running on pure battery power and the battery just can't handle everything electrical on the car by itself. Quote Link to comment Share on other sites More sharing options...
stef123 Posted September 9, 2012 Share Posted September 9, 2012 have these cars got electric power steering? if so then the ecu will switch it off when the alternator is not able to charge or there is a fault. if its a hydraulic pump driven by a belt you may well have lost the drive belt for power steering, alternator, a/c.. Quote Link to comment Share on other sites More sharing options...
tommy.h Posted September 11, 2012 Share Posted September 11, 2012 Hi check fuses 2,7,8 & 19 tom Quote Link to comment Share on other sites More sharing options...
