glyndwr Posted October 14, 2012 Share Posted October 14, 2012 Hi just wondering if anyone can help , my 2003 mondeo tdci temp gauge sticks halfway i turn engine off stays there , i then tap dash a few times needle will then drop , turn key in ignition needle will bounce straight back to halfway point ,, i phone local ford dealership was told needs new cluster at cost of £435 plus vat and labour ,, any help please im hopeless with these things . cheers martin Quote Link to comment Share on other sites More sharing options...
Lenny Posted October 14, 2012 Share Posted October 14, 2012 Hi just wondering if anyone can help , my 2003 mondeo tdci temp gauge sticks halfway i turn engine off stays there , i then tap dash a few times needle will then drop , turn key in ignition needle will bounce straight back to halfway point ,, i phone local ford dealership was told needs new cluster at cost of £435 plus vat and labour ,, any help please im hopeless with these things . cheers martin Try performing "Gauge Sweep" a couple of times to free up the needle, maybe dust on it restricting movement. Gauge sweep can be done by accessing the secret menu on your ford. Simply push in the button on the top of the wiper stalk while pushing down on the scroll wheel then while pressing these. Turn the ignition from off to step 2. Don't start the engine just turn to 2 while buttons pressed and watch for the dial to change. You can then scroll through settings by pressing enter Also the gauge panel is coded to the GEM, ECU and ignition so it would require some programming by ford to be compatable with your specific model so buying on from the breakers wouldn't be a straight fit function. If the gauge persists to lack function, I would consider fitting a "ScangaugeII" and use it to monitor levels instead of a new cluster. The "ScangaugeII" plugs in to the OBD port in your car and mounts to the dash to display 4 digital readouts at a time chosen by yourself including oil temp, engine temp, exhaust temp, boost, coolant etc. Its backlight colour can also be set to match your existing backlight colour scheme. Quote Link to comment Share on other sites More sharing options...
glyndwr Posted October 14, 2012 Author Share Posted October 14, 2012 i dont have anything on my indicator stalk ,,,i dont have any idea what "ScangaugeIl is i will google now Quote Link to comment Share on other sites More sharing options...
glyndwr Posted October 22, 2012 Author Share Posted October 22, 2012 scangauge not suitable for my car im told ,, wont work only from 2004 onwards ???? the suggest i try somebody elses to try it first lol Quote Link to comment Share on other sites More sharing options...
Lenny Posted October 22, 2012 Share Posted October 22, 2012 scangauge not suitable for my car im told ,, wont work only from 2004 onwards ???? the suggest i try somebody elses to try it first lol It may still work mate, I've saw Mk1 focus with scangauge fitted on focusownersclub.com and fordfocusownersclub.com The Mk1 is from 1998-2004 Perhaps contact scangauge company directly through their website. Quote Link to comment Share on other sites More sharing options...
glyndwr Posted October 22, 2012 Author Share Posted October 22, 2012 cheers Lenny Quote Link to comment Share on other sites More sharing options...
