Carpets Flooded
focused man
Not an understatment, foam under carpets is ringing wet. What things should I check? Does it cause lasting damage? Thanks
is this in the passenger footwell by any chance,if it is check the pollen filter housing at the windscreen its a common place for water ingress.has the filter been changed lately
Yes, passenger side and probably more on the drivers side. Checked last service (12mnths ago) just states odour filter changed. How would the pollen filter cause water to get in?
pollen filter does not leak on mk 2 or 2.5 more likely a blocked aircon drain under the drivers side carpet or a leak from the windscreen
  • 1 month later...
Hope it's sorted, but if not my problem was the bulk head seals
these bulkhead seals should now be done by ford free as many owners seem to have the issue and its well known there was an issue
