jayh1986 Posted December 28, 2012 Share Posted December 28, 2012 Hi there, I have a Focus 1.6 55 plate and have a slight coolant leak. It is leaking from a part which is bolted onto the side of the head. It has two pipes coming off it and some sort of sensor or something screwed into it. It is directly underneath the coil pack. Pipes from it fo to the radiator and through the fire wall. I've looked in the haynes manual and it is not the thermostat, as it says that is underneath the alternator. This is the opposite side of the engine. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2012 Share Posted December 28, 2012 Hi there, I have a Focus 1.6 55 plate and have a slight coolant leak. It is leaking from a part which is bolted onto the side of the head. It has two pipes coming off it and some sort of sensor or something screwed into it. It is directly underneath the coil pack. Pipes from it fo to the radiator and through the fire wall. I've looked in the haynes manual and it is not the thermostat, as it says that is underneath the alternator. This is the opposite side of the engine. Any help appreciated. the part you describe does sound like the thermostat housing, more so as there is a pipe to the radiator. Quote Link to comment Share on other sites More sharing options...
jayh1986 Posted December 28, 2012 Author Share Posted December 28, 2012 Ok thank you. The reason I was asking was, as stated above, in the haynes manual it says to take off the alternator to get to the thermostat, where this is directly under the coil pack itself nowhere near the alternator. Searching on-line I have seen it mentioned that the thermostats have a black plastic housing. However the bit I am referring to is metal. If I look under the alternator I can also see pipes from the radiator leading to something under there, which is why i presumed that was the thermostat and this other bit something else. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2012 Share Posted December 28, 2012 Ok thank you. The reason I was asking was, as stated above, in the haynes manual it says to take off the alternator to get to the thermostat, where this is directly under the coil pack itself nowhere near the alternator. Searching on-line I have seen it mentioned that the thermostats have a black plastic housing. However the bit I am referring to is metal. If I look under the alternator I can also see pipes from the radiator leading to something under there, which is why i presumed that was the thermostat and this other bit something else. do you know if your car has an oil cooler? this will have a thermostat also and will be on that side under the alternator somewhere Quote Link to comment Share on other sites More sharing options...
jayh1986 Posted December 28, 2012 Author Share Posted December 28, 2012 Don't think so, not 100% though. Its looks basically like a lump of metal bolted to the side of the head with two hoses and some sort of sensor, and it is from this joint that it is leaking I can see slightly where the gasket looks like it has slipped allowing it to leak. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2012 Share Posted December 28, 2012 Don't think so, not 100% though. Its looks basically like a lump of metal bolted to the side of the head with two hoses and some sort of sensor, and it is from this joint that it is leaking I can see slightly where the gasket looks like it has slipped allowing it to leak. the sensor will be for coolant temp. is the gasket for the sensor? like a rubber O-ring seal? Quote Link to comment Share on other sites More sharing options...
jayh1986 Posted December 28, 2012 Author Share Posted December 28, 2012 No it looks like its a gasket where the "lump" lol meets the engine. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2012 Share Posted December 28, 2012 sorry i have just read your first post again and realised its a 1.6 petrol presumably? so it wont have an oil cooler to answer my own question lol. If no one has an answer for you tonight i will have a look at a 1.6 55 plate as it happens tomorow and see if i can get you an answer. Quote Link to comment Share on other sites More sharing options...
jayh1986 Posted December 28, 2012 Author Share Posted December 28, 2012 ok thank you very much. Like I said earlier. The coil pack is bolted to a bracket which is directly above the bit I am describing. Thank you for your help so far. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 30, 2012 Share Posted December 30, 2012 hi mate, very sorry I haven't had the chance to look for you, if the car is available tonight i will try my best Quote Link to comment Share on other sites More sharing options...
jayh1986 Posted January 13, 2013 Author Share Posted January 13, 2013 No problem. still haven't found out what this is, so until I can get a gasket it's a case of having to top up the coolant every now and then. It's not a massive leak and only leaks when the engine is running. Quote Link to comment Share on other sites More sharing options...
martyntdci Posted January 13, 2013 Share Posted January 13, 2013 can you take a photo and post it up? Quote Link to comment Share on other sites More sharing options...
