mattyr Posted December 26, 2012 Share Posted December 26, 2012 hi everyone please help have just bought this car and when cold it idles like its running on 3 cylinders ..runs fine when warm,checked codes nothing showed up..have tryed and check egr its fine any idears Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted December 28, 2012 Share Posted December 28, 2012 Try changing your HT leads/spark plugs, if its still happening possible coil pack? I had that on my 03 plate fiesta Quote Link to comment Share on other sites More sharing options...
mattyr Posted December 29, 2012 Author Share Posted December 29, 2012 Try changing your HT leads/spark plugs, if its still happening possible coil pack? I had that on my 03 plate fiesta hi m8 its a diesel.....but may have found the faul think its number two injector removed the plugs off the injectors when the engines cold number 1,3,4 injectors caused the engine tu run worse but there was no change when i removed number 2....if i buy a injector with the same part number and fit it is it easy to recode them or is it a main deal job Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted December 29, 2012 Share Posted December 29, 2012 No idea mate. I only said ths coil pack because I had a similar problem with mine but mines a petrol Quote Link to comment Share on other sites More sharing options...
mattyr Posted December 30, 2012 Author Share Posted December 30, 2012 rough idle problem,hi think i have an injector fault,when cold if i remove plug from injector 2 the engine rough idle doesnt change when i remove plugs from 1,3,4 injector the car idles even worse. so it seems number 2 injectors not working right.....tried this when engines warm and running right and number 2 injector causes misfire like the other injectors if removed....anyone had this fault...and if it is an injector 2 fault can i change the injector for a new one with the same part number....please help Quote Link to comment Share on other sites More sharing options...
DieselPig Posted December 30, 2012 Share Posted December 30, 2012 If you just bought it from a dealer take it back and complain.! As it runs ok when warm it sounds like a glowplug has failed. Quote Link to comment Share on other sites More sharing options...
