tippwarrior Posted January 11, 2013 Share Posted January 11, 2013 Hi I drive 2002 mk3 mondeo. Recently the coolant level drops to just below the minimum mark. If I top up it just drops to the same level again. It drops to this level and no further. Could anybody tell me what the problem is here. Thanks. Quote Link to comment Share on other sites More sharing options...
ivo Posted January 11, 2013 Share Posted January 11, 2013 you put to much ,never go over two lines min and max tach maximum aloued , if its more den this mark the couling system will trugg out. You hawe no problem! Quote Link to comment Share on other sites More sharing options...
tippwarrior Posted January 11, 2013 Author Share Posted January 11, 2013 you put to much ,never go over two lines min and max tach maximum aloued , if its more den this mark the couling system will trugg out. You hawe no problem! Thanks for your reply, thing is it always settled at just below max when it was cold up to now. Surely having it below minimum isn't right. Quote Link to comment Share on other sites More sharing options...
