Fault Code Dtc 9601
Focus_IRE
Hi lads,
I am wondering of any of you have got the same fault or have had the same symptoms? I have and engine system fault coming up on my car, the car is driving perfectly to me no limp mode or nothing, I have changed the fuel filter only today and the fault is still on can anyone guide me to what is actually wrong please? And it it my original key that using since first day.
ive just looked throu my code book, but dont have that code in there. they all start with p0
I would assume that code came up on a dash check?
It usually refers to a mismatched key.
That's normal as it comes from the factory when they insert the key for the first time on coding.
The engine systems fault is probably still on even though the fuel filter has been changed as I believe it needs resetting with a data reader.
@martyntdci - it is a code that came up on the dashboard trick check
@stoney - will I need to get it plugged in or will just disconnecting the battery for a while do the same thing?
