Guest Posted February 1, 2013 Share Posted February 1, 2013 Hi, My first post here. So hello to all! I have a 2008 Focus 1.8 TDCi (face lift model) having read allot on this forum it appears that the TDCi engines have a common issue with the EGR. I have the same problem with my car, when under high revs (above 2.5) mainly on 1st and 2nd gear after pulling off from a stop it stutters and sometimes gives an engine warning on the dash which will put the car on limp mode. I spoke to my mechanic and he pointed to the EGR which I also suspect is the cause of all this. My question from an newbie to you experts :) is; Shall I clean the EGR or block it with a plate? If I block it, would there be any performance issues ? Your thoughts / experiences would highly be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
IINexusII Posted February 1, 2013 Share Posted February 1, 2013 Hi, you can check this thread: Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2013 Share Posted February 1, 2013 Thanks, will have a look. Quote Link to comment Share on other sites More sharing options...
salsheikh Posted February 1, 2013 Share Posted February 1, 2013 The only issue you will face is that on the 1.8 the EGR is a pain to access as it is near the turbo so a pit will be required and removal of the exhaust and possibly turbo. ps. I might be getting mine done on weds so will update with pics if i can. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2013 Share Posted February 1, 2013 That would be great. If it looks complicated, I might get my mechanic to do it. Let me know how it goes and if you get any engine warnings if you do so. I do not have the equipment to reset the codes. Quote Link to comment Share on other sites More sharing options...
salsheikh Posted February 1, 2013 Share Posted February 1, 2013 will do. i have a bluetooth obd2 adapter (ebay) and the torque app (android and poss apple) so can clear the codes using this. Quote Link to comment Share on other sites More sharing options...
