Focus Bulb Lists
DanGersFord
Hey guys
Im going to change my head lights (bulbs) to better ones
should I replace both the main bulbs and dipped bulbs? or not worth change the dipped ones?
Replace both, with either osram night breaker or Philips brite vision
Highbeams - osram cool blue intense (excellent for motorways) dipped - nightbreaker unlimited.
Is there a big difference between the standard bulbs and OSRAM/Phillips for main beams? I've always thought they are good anyway. Might be worth an upgrade if there's more to be had..
they should be in my gallery, can you see them?
Those are the same as the side lights. Not sure if you had an answer on this..
Yes there is a difference as generally you can put our up to 100 percent more light than standard. Basically standard bulbs offer standard performance but with longer life, whereas you can trade some life for much better output.
cheers mate
will do that
so that's H1 and H4's
Believe so yes, double check the top of the post as I'm on the mobile so it's a nuisance.
cheers mate
will do that
If it's for the MK2.5 Focus its H7 for dipped beams and H1 for mains.
  • 3 weeks later...
Hey
Can anyone confirm what numberplate bulb i need.
I have a tit x (2013 and it has 1 bulb not 2
I want to put a brighter led bulb in there.
Also Can you confirm what type of reverse bulbs it has as want to cree them :-)
Jamie
Does anyone use this board anymore ?
can you help me plz sir :-)
I thought the plate light on your car was an led already?
Pretty sure the reverse bulb is a 382 (aka P21W or BA15)
Hopefully others can confirm.
didn't you get a manual for your car? it should be in there
  • 3 weeks later...
Thankyou Stoney.
Jamie
ok I have a 08 focus which currently the two headlights have blown and all i need to know is how many pins does the bulb have is it three or two.
looking at the Halfords website and they have a lovely set of Xenon headlights and side lights but the numbers on the box says 477 and H7 would that work?
H7 for dipped and H1 for main.
All 2 pin as they're single filament bulbs.
Am I right in saying these aren't actually xenons though? just xenon effect....
not xeonos no, but when bought new, you had the option to upgrade to xenons I belive
Not for the Mk 3 Zetec S which I drive...
  • 3 weeks later...
Thanks, this is really handy.
