Focus Bulb Lists
DanGersFord
 Share
Sorry for necroing a thread to add some info.
Was checking the bulbs last night on my, the rear cluster is the OEM Ford LED lights and the two bulbs are different from the standard Mk 3.5 light cluster. They are P27/7W for brakes and PY27/7W for the indicators Reverse bulbs remain the same.
Was going to replace the P27/7W bulbs with Osram LED (Red) for my next project especially people don't pay attention to brake lights round here but trying to find PY27 chrome bulbs is challenging.
Link to comment
  • 3 months later...
So I what to upgrade my H7 headlights to LED's so got the LEDs with the error free link up for them work totally fine no errors but as soon as the engine is turned on the lights go off after a few seconds, can anyone help what am I missing ?? or is there a kit especially for the mk3 ??
Link to comment
  • 5 months later...
Has anyone got a list for a Mk3.5 Estate, Titanium X which has the LED taillights? I can't believe that it'd be a 21/5w bulb for the brakes as it's only a brake light with separate LED tail, not a combined brake/tail.
To be honest, I'm being lazy about taking off the rear clusters just to check what bulbs are actually in there.
Link to comment
In response to my above post, I looked through the lens yesterday and it is in fact still a 21/5w bulb, it just never uses the sidelight part of the bulb! Crazy.
Link to comment
Not crazy if you're bulk buying!  Cheaper to stick dual filament in everything instead of buying ~10% single filament for the higher spec models. :smile:
Link to comment
  • 2 months later...
Has anyone changed the ceiling lights in the interior of focus mk4?
I want to open and change them but I don't know at all how this opens.
Link to comment
Intrigued to know why would you want to change them ? They're LED'S anyway.
  • Like 2
Link to comment
  • 2 months later...
  • 6 months later...
Hi guys I have a Ford focus 1500 diesel titanium 67 plate (2017) it has led dipped I've been searching for one that compatible HRD  with a litt fan at th back has anyone got any idea which one I need.
Link to comment
  • 7 months later...
So long as you have replaced "like" for "like" Halogen for Halogen then there will be no problem about the colour unless it is more blue than white. I have fitted many of the super white bulbs (look blue when switched off) and they do not cause any problems at MOT time.
Link to comment
  • 3 weeks later...
  • 10 months later...
Does any model of Focus use 21w/4w Brake / Tail light bulbs?
These are not the same as the common 21w/5w bulbs. The 21/5w type won't fit as the pins are aligned differently. These bulbs are clear, and not the red type that the Mk 2.5 Focus used.
Apparently some newer Mondeos use them, and they can be more difficult to find as not many places stock them.
Link to comment
19 hours ago, unofix said:
Amazon
Of course they can be ordered if need be, but are not common in shops.
They are also never included in the generic spare kits.
I don't understand what advantage this obscure bulb type has over the 21/5w.
Link to comment
Typically 21/5W are commonly referred to as 'Stop & Tail'
The 21/4W (Type 566) were initially designed to be used as 'Fog & Tail' and are for vehicles that use a combined rear fog and tail light.
Given that there are over 100 different lamps in common use on vehicles, I expect that a generic spare kit would be lucky to cover 50% of any cars lamps.
Standard stock item in both Halfords and Euro Car Parts to name two. Not a common item in Poundland or Aldi.
Link to comment
In my opinion, a good thing about the Mk2 pre-facelift Focus is that all the bulbs are very common standard types.
The kits they sell in Tesco cover most of them, apart from the orange indicator ones. The orange paint usually peels off them long before they burn out anyway. In all my time driving, I have only ever had one actually fail that I can remember.
Link to comment
  • 2 months later...
Merhabalar 2012 Focus 3 araç lamba arızalarında gösterge ekranından ikaz veriyor fakat arka stop lambası arızasında ikaz vermiyor sebebi ne olabilir?
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
