balloo Posted March 1, 2013 Share Posted March 1, 2013 hi all ,joined up today on behalf of a freind with a mondeo tdci zetec and wondered if any helpfull souls can shed some light on the problems,sometimes all is fine but on ocasions when you turn the lights on firstly the speedo and rev counter do a sweep,no illumination of the spedo and rev counter,both indicator warning lights light up and stay on as does the high beam light !,and as far as i can understand the lights are on full beam and wont change to low,It can stay like this for a few mins or i think the longest has been a few days then all goes normal again !otherwise all else seems fine has anyone else had anything like this or any sugestions?thanks for taking the time to read and look forward to any help .all the best ;) Quote Link to comment Share on other sites More sharing options...
BigD Posted March 1, 2013 Share Posted March 1, 2013 The dial sweep/all lights on is a classic symptom of a failing battery. Any trouble starting? Have you had a multimeter on the battery? You should be showing about 14.4V. There could be a bad earth somewhere but I have no idea where most of the earth points are. Also, I assume the Mk4 needs a Calcium Silver battery like the Mk3 does. Is that the type of battery he has, because if it is like the Mk3, then a normal lead-acid battery is no good. Quote Link to comment Share on other sites More sharing options...
balloo Posted March 2, 2013 Author Share Posted March 2, 2013 hi :) thanks for the reply the car starts o.k and works cool in the day ..its when you turn on the lights it goes bonkers will for sure have a check of the batterey many thanks ..chris Quote Link to comment Share on other sites More sharing options...
