Freek_Ba Posted March 2, 2013 Share Posted March 2, 2013 Hello everybody, I am a last year engeneering student from Belgium and for my thesis I am working on a 2001 1.6 Zetec engine. I took the engine out of a side damaged Fiesta and built a frame to hold the engine (I'll post pictures later). The engine wil get mounted on a Superflow testing module (see picture). http://www.superflow.com/news/wp-content/uploads/2011/09/SuperFlowTestCell1.jpg Wen i'll have it working on the original ECU, I will change the ECU for a programmable one based on MegaSquirt. Guessing I will bump on some problems I have started this topic. I hope you guys can help me. My first question: Why are there 2 lambda-sensors? There is one before the kat (a green fiche) and one behind it (blue fiche). This will not give any problems with the original ECU, but it will in the new one where I only need one. Greeting, Freek. Quote Link to comment Share on other sites More sharing options...
DieselPig Posted March 2, 2013 Share Posted March 2, 2013 Pre-catalytic sensor is to control the fuel-air mixture, post catalytic sensor monitors the performance of the catalytic converter. Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted March 5, 2013 Share Posted March 5, 2013 I would say you need both in any situation even on a setup such as the one that you are building, anyway good luck with your course. Quote Link to comment Share on other sites More sharing options...
Freek_Ba Posted May 27, 2013 Author Share Posted May 27, 2013 We have got the engine running but it is not on full power. I can see that there is a problem with the ignition. When we open the throttle, the ignition goes the wrong way (20 degrees later in stead of earlier). I hope you understand what i mean with this. We have reduced the cables to the exact minimum we need. Does anyone know what the problem could be? Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted May 27, 2013 Share Posted May 27, 2013 Sounds like your missing some sensor data still. Quote Link to comment Share on other sites More sharing options...
