billbo11153 Posted March 15, 2013 Share Posted March 15, 2013 can you help was driving this morning car going fine ,could here fuel sender power from back take ages to stop whining when driving just dies stops turn all of re/start starts for second then dies check fuses read manual gets tow nothing its like no fuel but there is diesel in tank when turn key now getting clicken like starter moter also all clocks reset go all way round then nothing can anyone sugest what is wrong Quote Link to comment Share on other sites More sharing options...
Sliveredge Posted March 16, 2013 Share Posted March 16, 2013 sounds like battery if flat with the dials and clicking of the starter motor. could be a faulty alt not charging the battery therefore why it died while running. get a multimeter on it check the voltage of the battery with ignition on and also when trying to start the car. Quote Link to comment Share on other sites More sharing options...
Blader Posted March 16, 2013 Share Posted March 16, 2013 We had the same thing with our Fiesta 1 week after buying it from the main dealer, totally nothing, no lights inside or out, dash lights, interior lights radio, called the RAC out and he went straight to the battery connections (which I had tried) tightened up the clamps and hey presto we had light. Turns out he said that the clamp that holds the battery down doesn't, and the battery moves slighty and the terminals works slightly loose. Hopefully this will solve your problem. Quote Link to comment Share on other sites More sharing options...
Blader Posted March 16, 2013 Share Posted March 16, 2013 Forgot to add, when I got home I took the battery clamp off, put a small strip of rubber on top of the battery where the clamp fits down and tightened the clamp up, no more loose battery. Quote Link to comment Share on other sites More sharing options...
