frostman83 Posted March 24, 2013 Share Posted March 24, 2013 Alright chaps. Had problems with starting my 59 plate 1.6 zetec. Took it back under warrenty and they put a new battey in. Problem solved. Now about 3 weeks later its not as smooth as it was. The other day it wouldn't start twice at all but started 3rd time and was fine. Today it stated up 1st time but sounds a little croggy. It's like it's not a clean quick start if you no what I mean. Any suggestions? Mabye a can of bg44k or whatever it's called? The car runs perfectly when stated and sounds as It should do. Very strange. Quote Link to comment Share on other sites More sharing options...
Brigante Posted March 24, 2013 Share Posted March 24, 2013 this sounds the exact same problem i had a few months back about once a month my car would refuse to start, and eventually start on the 2nd-4th attempt then drive fine as normal n start fine as normal till about a month later first port of call was the battery, took it to halfrauds to get the battery tested n it was only showing about 60% start power or whatever it was n it was the original ford battery that was put in 7 years ago. thought i may as well buy a new battery n trumped for top of the range Bosch silver month later, car doesnt start so it wasn't the battery that was the problem ran a can off bg44k through me pipes n the car has started beautifully first time every time and its been several months since i had starting problems now so it would appear me pipes was just clogged up its worth trying it yourself n see if its the same for you. cant tell whether you have a petrol or diesel but if it's a petrol you need bg44k n if its diesel you need bg244k what i will also say though is about a month ago my engine management light came on 2 occasions about a week apart. i had a diagnostic done and it spat put fault code p2303 which relates to the coil pack the coil pack going can also cause the car not to start and can also cause misfire as well as making the eml come on it can be a cheap fix though as the coil pack is only 30quid for genuine Bosch on eBay which is the same as what ford use so in the near future i will be purchasing a new coil pack n fitting that also Quote Link to comment Share on other sites More sharing options...
frostman83 Posted March 24, 2013 Author Share Posted March 24, 2013 Cheers good read. It's a petrol engine I will give it a try Quote Link to comment Share on other sites More sharing options...
Brigante Posted March 24, 2013 Share Posted March 24, 2013 get yourself one of these then http://www.ebay.co.uk/itm/BG44K-BG-44K-Fuel-System-and-Injector-Cleaner-/200786474899?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item2ebfce7793 same link i used. cant do any harm n you may find this will solve your starting problems it may be worth getting a diagnostic done as well though to see if there are any fault codes Quote Link to comment Share on other sites More sharing options...
frostman83 Posted March 24, 2013 Author Share Posted March 24, 2013 Thanks for the link. Will order some. Can I ask did u run the petrol to a quarter left and then put it in? Or do I add the whole can to a tank ? Tar. Quote Link to comment Share on other sites More sharing options...
Brigante Posted March 24, 2013 Share Posted March 24, 2013 i did it on a full tank but used a bit first to make room for it if you get what i mean? actually what i did was i filled up, then i had to drive from nottingham to birmingham anyway so i drove an hour to birmingham, this made more than enough room for the bg44k n i poured the whole can in my tank when i got there really though just doing a few miles will make enough room for it then i just drove the car as normal n ran the tank down to a quarter n filled up again as normal. this is more than enough to give the bg44k a good flush through the pipes n i've had no starting problems since. i'm sure it must be nearly half a year ago now n like i said its started first time every time even in harsh weather like we having now 1 Quote Link to comment Share on other sites More sharing options...
frostman83 Posted March 24, 2013 Author Share Posted March 24, 2013 That's great. Appreciate your help. Quote Link to comment Share on other sites More sharing options...
Brigante Posted March 24, 2013 Share Posted March 24, 2013 any time buddy glad i could be of service Quote Link to comment Share on other sites More sharing options...
grahamp Posted March 25, 2013 Share Posted March 25, 2013 If you bought the car fairly recently its possible the engine was steam cleaned, sometimes water / detergent can get where it shouldn't, eg the starter motor perhaps. Just a thought... Quote Link to comment Share on other sites More sharing options...
frostman83 Posted March 25, 2013 Author Share Posted March 25, 2013 stange thing is i took it out twice last night, i used my other key and this time put foot down on the clutch when starting and it was fine.no problems whatsoever. could it be the car still thinks its fairly warm and doesn't give enough petrol? Quote Link to comment Share on other sites More sharing options...
